Help Me Recap my IC7-G max II
  • TFlight
    • Jan 2011
    Hi Everybody,
    I'm new to these forums. I have an older system with an IC7-G Max II board that has some bad caps around the CPU Power Section of the board. The ones that are swelled up and have the tell-tale brown crust are 6.3v 2200 microfarad electolytic Rubycons. I suspect they might be counterfeit, because they do not have the "K" type marking like they should...they have an equlilateral tri type vent stamping in the top of the cans. This rig has not been booted up. These caps failed while the rig was sitting in a closet, so I'm fairly certain I can salavage the rig.
    I would like to replace the caps with better qualituy caps, or even get rid of the electrolytics, and replace them with Polys, but I see there are some rules to follow, and I'm not real sure of all the rules, and the exceptions to those rules.
    I'd like help from the pros on recapping this board, because I wnat to be sure I can salavage it and make it last over the long haul. This system in it's day was one of the highest end OC'ing rigs you could get, and I plan to use it in conjunction with many other rigs in a flight simulator setup. The board is now irreplaceable, because ABit is no longer in buisness.
    Any help you could provide would be much appreciated.
  • bigbeark
    • Jan 2010
    • 661
    Re: Help Me Recap my IC7-G max II
    If they are MBZ Rubycons they should be dark blue with a gold stripe and a K vent. MBZs in 6.3v 2200uf measure 10 x 20mm.
    I would replace the leaking ones with new 6.3V 2200 MBZ Rubycons and see if the board boots up and works properly before getting into Poly conversion.
    Socket 478 CPUs with the Prescott core get pretty hot. If you are going to do heavy-duty gaming/video work you need a better cooling system than stock. Liquid cooling makes sense for the NetBurst CPUs.
    I use a solid copper heatsink on my GigaByte i875 board but even that's not enough for heavy-duty use.
    • TFlight
      • Jan 2011
      Yep, cooling is already taken care of on that rig. It was OC'd before, but will be reduced some. I'm mainly using this as a second computer on my flight simultor that will be used for displays in the cockpit.
      This is an F-16 simulator. It doesn't take a massively strong rig for that or even high end video cards...just something that is capable of supporting 5 small low res monitors. It does this by being networked to the main rig, and the programs that output the data to the screens are brough up and those hit the shared memory of the simualtor and they output the data. It's a little more complicated than that, but that's the general idea.
      This old rig is perfect for that. I also have to admit that I kinda have an attachment to that rig because when it was new and I built it I actually set a record doing some performance benchmarking with it.
      The reason I was leaning more toward poly caps is because I do not want that leaking to occur again. I want to makew that computer very reliable and last, because it's old, and irreplaceable, and it can do a job for me and actually do it better than some of the new hardware believe it or not.
      That old board with the 3.2 Prescott (yes I'm well versed in the "preshott's" hehe) did some amazing things back in it's day, and it has some sentimetal value. I want to make sure it can do some amazing things again in a different way, but want to make sure it lasts over the long haul.
        ASUS P5GC-MX motherboard recap
        by momaka
        Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
        This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
        So here is what the motherboard looked like with its original caps:
        CPU VRM area up close…...
        01-27-2021, 11:59 PM
        no-name Radeon 9600 XT recap and cooler
        by momaka
        I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
        This one was actually suggested to me by ChaosLegionnaire....
        11-06-2020, 07:54 PM
      • varunviolin007
        Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
        by varunviolin007
        Hi guys,
        I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
        I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
        Looking for someone experienced with older PC boards who uses...
        07-29-2025, 11:53 PM
      • Foetuss
        Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
        by Foetuss
        Hi all
        Hope this is in the correct place.
        I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
        Could use some double checking to see if I'm not doing something stupid .
        Pictures of the boards are attached.
        What I will be replacing with what : (planned)
        Soltek Golden ::
        4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
        6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
        01-18-2025, 11:44 AM
      • goodpsusearch
        Got 4 LG L222WS 22" for free - psu recap
        by goodpsusearch
        Got 4 CCFL 16/10 monitors for free.
        The resolution is almost Full HD (1680x1050)
        VGA Input only is a bummer though.
        Uses cheap TN panel with terrible viewing angles.
        Even though this is not 17" 5:4 screen, still has very low resell value here. Can be found for 15-20 euros.
        All the 4 monitors were not working and needed psu recap. Used mix of mediocre / junk caps to recap them, then donated 3 of them to friends/relatives and kept 1 for myself. Also like to install extra caps on empty spaces to help them last longer.
        01-15-2022, 05:36 PM
