ECS D6VAA Bad Caps!!
  • Belial
    • Dec 2003
    Hello guys,
    I've this board for two years now, and from time to time I open my case to clean it, and yesterday I saw a swollen cap on top, near the atx power connector. I have some basic knowledge in electronics and I know that this is not good, although my board is running perfectly, I'm worried because I know that it will crash very soon. The ECS D6VAA http://www.ecsusa.com/products/d6vaa.html is a dual socket 370 board such as the VP6 that is covered in the site. Has anyone of you experienced this bad cap problem with this board? I want to do something like you describe for the VP6 on my D6VAA, could anyone give me some advice, like which caps should I change, and which are the good cap brands I should look for?
    Thanks in advance,
    Belial
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    time to change them NOW.
    if you use high quality caps like panasonic,sanyo,nichicon,rubycon ect you will not have any more cap trouble for the rest of the boards usefull life.
    ]they MUST be low esr type!
    post the brand of the bad caps in the sticky at the top of this forum.
    pics are welcome too.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      I would recap it before it gets worse! If one of the failing caps shorts, it can sometimes cause irreversible damage to your board and even CPU's and RAM.
      If you need a hand, let me know.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        and it WILL get worse.
          by momaka
          03-15-2023, 10:17 PM
        • black6host
          Replacement caps for Samson Resolv studio monitor 65A Amp board.
          by black6host
          Good day!
          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
          I'm going to replace the caps and I'll be the first...
          02-06-2024, 08:22 PM
        • lostone
          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
          by lostone
          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
          05-19-2024, 11:40 AM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
