Recapping Asus Board with Cool Stack
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Recapping Asus Board with Cool Stack
    The very first solder iron I ever used was heated by sticking it in the fire in the stove.
    [A coal burning stove no less.]
    It was my grand father's.
    Mann-Made Global Warming.
    - Dr Seuss
    • larrymoencurly
      • Oct 2004
      • 960
      Originally posted by mockingbird
      No, I'm not using chipquick. Your problem is your flux is weak. I use plumbing flux with my 25 or 35 watt irons and I have no problems. I can even desolder large coils from multi-layered boards. The 35-watt I found in the trash. If this hobby makes me a million dollars someday, I might consider investing in one of those overpriced irons, but until then, I refuse to pay.
      I don't have the courage to try zinc chloride acid flux on circuit boards, and while I've seen rosin flux help make copper desoldering braid work better, it otherwise hasn't improved my luck with circuit boards. I do remember needing more than 25W to remove a 1.5-2.0" cube transformer form a single-layer board, and I don't think the problem was poor conduction between the tip and solder. I've never paid more than $5 for an iron, not even for my adjustable 10-60W, except for an $11 Radio Shack desoldering iron.
      • larrymoencurly
        • Oct 2004
        • 960
        How well did it work on surface mount chips?
        How about for branding cattle?
        • Pyr0Beast
          • Feb 2009
          • 406
          Zinc Chloride flux is quite nice to work with, but it needs a bit higher temperatures to function properly and it is also quite wet and spews everywhere.
          It removes oxides nicely, tho it doesn't improve wettability much. Ordinary flux is much better for this purpose.
          It however does _magic_ on old copper wires (and is corrosive as hell if you hadn't cleaned it properly)
          Fumes of such flux are also quite aggressive on your lungs and with no ventilation I would not recommend it.
          Plumbing flux is something I would avoid as they are mostly acid based.
          I dip my braid in colophony and 'tin' it a bit, works much better then, despite being a bit contraproductive, but you can't heat the pad with dry braid, does not work.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            I dunno. I was about 10 or 11.
            Worked pretty good for soldering tin cans together.
            - Dr Seuss
            • dhamrin
              • Jul 2011
              • 4
              #26
              Just recapped a Asus P5AD2-E Premium with no success. Board LED lights, fans come up, but no beep, no post, no monitor. Wondering if the process of resoldering Stack Cool could have anything to do with it? When I replaced the caps, I soldered the caps to the Stack Cool, assuming/hoping the solder somehow drops onto the contact on the primary motherboard. Is that how it works? Does the Stack Cool have any electrical contact with the primary motherboard?
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                #27
                a 25w iron will only do the job if it has enough thermal mass.
                25w radio shack cheapie?
                fugettaboutit!
                • DynaxSC
                  ASUS STRIX Z490-F GAMING - No POST, stubborn board
                  by DynaxSC
                  I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
                  The situation looks like this:
                  After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
                  1. RTC oscillates normally (32.768KHz).
                  07-08-2022, 05:45 AM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • ShadowAi12
                  ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                  by ShadowAi12
                  I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                  • The board enters a "ready to power on" state after plugging in the PSU.
                  • Pressing the power button increases power draw.
                  • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                  Measurements:
                  (taken after pressing the power button, while the board is attempting to start)
                  • H_SKTOOC#
                  06-11-2025, 01:05 PM
                • jimbodriver
                  Faulty ASUS X99-PRO board. Some progress with repair. Need advice\help please.
                  by jimbodriver
                  I am trying to learn electronics repair. I purchased a “faulty for spares/repairs” ASUS X99-PRO/ USB 3.1 motherboard for a very low price from ebay – a good enough price to offset the high probability that the board was completely toast and not realistically repairable.
                  Initial results:
                  Board would power-cycle when turned on either with switch on board or shorting pwr pins. Fan would spin for a second or so and a QCODE of 00 would display then it would power off and then do the same thing again over and over. I think maybe 2 times in about 100 attempts...
                  03-20-2022, 02:30 PM
