Plcc32 usb stick to be find to program plcc32?
  • Oldschool297
    • Jun 2023
    • 24
    • Sweden
    Any usb stick to be found that can insert bios to plcc32 32pin?
    by Vesko356
    08-11-2023, 03:27 AM
  • ezenia
    PS4 controller left stick potentiometer replacement issue
    by ezenia
    Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
    So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
    I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
    09-30-2023, 02:19 PM
  • danielgerman681
    ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
    by danielgerman681
    Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
    08-27-2025, 01:17 PM
  • traxformania
    TONGFANG "GM7TG7P" Bios Password Problem?
    by traxformania
    I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
    But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
    I'm trying to reset my bios without success.
    I tried :
    -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
    11-15-2023, 07:32 AM
  • corrize
    Where to find a very small fpc connector 0.3mm between 2 pins ?
    by corrize
    Hello, I search this connector (oxydated).
    It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
    I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
    I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
    Do you know how to find this connector please ? What is the exact name for find it ?
    08-06-2024, 05:25 PM
