Asus Rampage III Extreme No Power
  • ohallahan
    • Aug 2023
    • 6
    • US
    I have an Asus Rampage III Extreme that made a pop noise and just shut off and won't turn back on.
    Nothing really looks blown that I can see, I already tested every thing I can so far.
    The only thing I could see as a possibility is what looks to maybe be common mode choke filters near the capacitors near the CPU that say EMC on them but I can't make out exactly what the numbers are and googling doesn't really bring anything up.
    They look to say R301HF A112 ?
    The bottom one looked to have some corrosion so that's what was leading me to believe that maybe they are bad or something.
    I have read all over online that everybody has had problems with these boards but nobody has posted on any kind of fixes for them.
    If anybody could help identify them I would appreciate it.
    Here's some pics
    https://ibb.co/d2S8gFD
    https://ibb.co/5hwcPRK
    https://ibb.co/YbbvtL8
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Asus Rampage III Extreme No Power
    Please attach pictures to your post directly.
    • ohallahan
      • Aug 2023
      • 6
      • US
      I don't see an edit button, I'll attach them here
      • McWhitePink
        • Apr 2023
        • 103
        those are inductors, as long as you don't measure open or high resistance from end to end they should be just good.
        • ohallahan
          • Aug 2023
          • 6
          • US
          Thanks for replying. Can you make heads or tails of the numbers written on them? I haven't had any luck with searching online yet
          I was just leaning towards them as a possible problem since I found corrosion on them, I don't see anything else off hand.
          • ohallahan
            • Aug 2023
            • 6
            • US
            I got a replacement board and the parts were easier to read. R30KHF is what they say and are on mouser.
            I tried the CPU in the replacement board and it wouldn't boot, so the old board and the CPU are both fried, so not sure what would have caused that.
            Hopefully I'll be able to go over the old board and try and find out what's wrong and I'll post about my findings online in case it helps somebody else.
            • McWhitePink
              • Apr 2023
              • 103
              do you still have the old board? Usually if 12V input is shorted to the VRM output it will burn the CPU. you can measure from the 12V input to the inductor pin to see if there is any short.
              • ohallahan
                • Aug 2023
                • 6
                • US
                Yes I still have it. I will check that once I get a chance, hopefully it's an easy fix and not too time consuming, the board is worth fixing.
                Thanks for taking the time to post.
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • ShadowAi
                  ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                  by ShadowAi
                  Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                  Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                  After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                  03-15-2024, 10:46 AM
                • meraklinetx
                  Asus Z97-a power cycle, no boot no cpu voltage
                  by meraklinetx
                  Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                  05-10-2023, 06:08 AM
