MSI K8N Neo (Socket 754) boot problem
+ More Options
Posts
  • jtctolits
    • Jul 2010
    • 10
    This motherboard together with Athlon 2800 were given to me. The problem of this mobo;
    - when i power on the AVR, without out pushing the power button of the cpu, it will power on immediately(cpu fan spinning) for 3 seconds. then power off.
    - then i push the power botton (after the cpu fan stops spinning), it will power on but; no display, no beep. The cpu fan just keep on spnning without booting.
    Troubleshooting done:
    - clear CMOS;
    - change CMOS battery;
    - reset memory;
    - reset processor;
    - change power supply;
    - i already workbench the unit with only the mobo, proc, mems and VC
    but still the problem still persists
    I did not see any bloated caps, the caps in the CPU area are 4 Rubycon 25V 820 mf, 8 Panasonic 6.3V 1500mf. The rest are OST's.
    TIA guys
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: MSI K8N Neo (Socket 754) boot problem
    got a post card?
    • jtctolits
      • Jul 2010
      • 10
      @ kc8adu
      i do not have a post card. i tried putting a PCI video card (S3 Trio) but to no avail
      here are the hardware;
      - MSI K8N Neo
      - Athlon 2800
      - Kingston 512 mb DDR1
      - ATI Radeon 9250 AGP
      - Hec Raptor 500watts
      • brethin
        • Dec 2008
        • 1907
        The board has a short somewhere. It should not power on like that unless the bios is set to return to last state. Since you cleared the CMOS the default setting for that is to stay powered down. I had that same board with that same exact issue. Never did find the short.
        • jtctolits
          • Jul 2010
          • 10
          i noticed that when i plug the CPU fan to the northbridge fan (3 pin) connector, it will not spin, thus, there is no power coming out of the northbridge fan pin (3 pin). It might be the north bridge has screwed.
          • ant3202
            • Jun 2006
            • 275
            • Singapore
            it maybe VRM IC chips module been fried
            • pkslowk
              Debug Card Error Code and Solution
              by pkslowk
              Sr. Motherboard Debug Error Code Solution
              1 Intel 845 E9 Bios Related Problem
              2 Intel 845 D4 CPU Socket Related problem
              3 Intel 845 37 Bios Related Problem
              4 Intel 845 7C Bios Related Problem
              5 Intel 945GCPE 34 Bios Related Problem
              6 Gigabyte 845 2 Ram Related Problem
              7 IBM Server A6 A7 Ram Mismatch Problem
              8 Asus 845 29 CPU Related Problem
              9 Lenovo I946 97 C-Mos Jumper related
              10 Gigabyte 845 A0 CPU Related Problem
              11 Asrock G31M-VS D7 Bios Related Problem
              12 Compaq 845 BD-70G B0 CPU Socket Related problem...
              01-28-2021, 12:51 PM
            • futadmytro
              Asus g713qm-es94 stuck on boot bios problem
              by futadmytro
              sn^M4NRKD02753616E
              MB- g533-6050a3250201-MB-A03
              Stuck on boot after ROG logo, did not enter to bios
              In flash bios , laprop boot but have video issue
              orig bios...
              06-25-2025, 08:07 AM
            • DynaxSC
              ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
              by DynaxSC
              I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
              Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
              Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
              The behaviour is also really very strange, i.e.:
              • The disk shows always up in BIOS - so it is recognized, so far so good
              • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
              02-23-2025, 01:33 PM
            • mpower1226
              Dell optiplex 7090 boot problem
              by mpower1226
              Hi masters, need your help in solving this mystery.
              i have a dell optiplex 7090 micro that i bought from local kijiji.
              when i turn it on, error comes out saying no hard disk.
              i go to bios to check the boot option, only httpboot shows. If i try to add boot option, it only shows file search but nothing happens when i click.
              i took out the ssd and put it into old laptop and format and installed the windows 10 and put it back into the desktop. It boots up and same error again no hard disk.
              it seems as if the computer doesnt recognize the ssd...
              01-22-2024, 10:37 PM
            • privato89
              Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
              by privato89
              I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
              Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
              Let's begin:
              Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
              03-26-2024, 06:37 AM
