hello, on our hp eliteone 800 g4; there is an automatic power-on when plugged in, 5 long 7 short beeps when turned on. Anyone come across or have a solution? thanks in advance
hp eliteone 800 g4
by retrorepair2I've got an issue with my Z820 that I'm having trouble working out the root cause of.
More often than not it'll turn onand fans will blast for a moment before stopping and I'll get 4 beeps that will repeat forever (at least the power light will keep flashing).
What I can't understand is sometimes it'll just work and I can use it all day but other times it'll boot then reboot then reboot and 4 beeps for the rest of the day. Sometimes it'll work fine from cold for hours, sometimes it'll do the 4 beeps from cold.
Another oddity is the fans. Before the 4 beeps... -
by ktmmotocrossHello.
Have this old hp compaq nc6320 that came with one long and one short beep + backlight on. bios battery have only 0.5V. I remove it, but now it start beep some weird way. I think it is bios /one long + two short beeps+ baklight on/, but when i flash new bios from hp, no beeps and no backlight.
i attach record of beeps...04-27-2025, 12:48 AM -
by KappaDevI have an HP Envy x360 15m-dr laptop which sometimes beeps 8 times on startup and sometimes gets no beeps at all (both with no picture).
Power button light comes on, fans spin and stop after a few seconds, then screen stays black with no picture. If the machine decides to beep 8 times, it shuts off immediately after. According to what I could find, 8 beeps was corrupted BIOS.
Made backup of original BIOS (attached). Attempted to flash BIOS with extracted bin file from HP BIOS update. Screen showed "Updating boot block", rebooted and immediately back to 8 beeps and... -
My Hp prodest 400 g5 having no display with or without ram 3 long beeps and 2 short beeps. many bios tried but the problem is same. please help thanks in advance.
by imadam123I have an old hp z420 workstation. When I power it on, it just power cycles. When I disconnect the power cable there is 4 long beeps and a red light at the power button. I've tried all the troubleshooting steps and none have worked
The 4 red beeps should be an indication of a bad PSU, but I've already tried a new one and there's no difference - Loading...
