Hp z420 power cycling, then 4 beeps when PSU plug removed
  • imadam123
    • Mar 2024
    • 8
    • northern ireland
    I have an old hp z420 workstation. When I power it on, it just power cycles. When I disconnect the power cable there is 4 long beeps and a red light at the power button. I've tried all the troubleshooting steps and none have worked
    The 4 red beeps should be an indication of a bad PSU, but I've already tried a new one and there's no difference
  • mon2
    • 14685
    Remove all power. Measure the RESISTANCE (not diode mode) of each inductor (2 legged and usually grey in color) on the board. You are checking for a low resistance which may be due to a shorted capacitor onboard which will trigger the local power supply to shut off.
    PS: I think I have one of the same units from when we did a design for HP.
    • imadam123
      • Mar 2024
      • 8
      • northern ireland
      Forgot about this thread, only rediscovered it when i was trying to fix this after a while. Measured them all and they all read ~0.250
      • imadam123
        • Mar 2024
        • 8
        • northern ireland
        left it off overnight, all measure 0.015 at the 2k mode on my multimeter
        • imadam123
          • Mar 2024
          • 8
          • northern ireland
          bump
          • imadam123
            • Mar 2024
            • 8
            • northern ireland
            Bump
            • hoaca388
              Badcaps
              • Jan 2022
              • 12347
              Originally posted by imadam123
              Bump
              "Bump" what ? You must upload the original bios file (even if it is corrupted) and serial number.
              • imadam123
                • Mar 2024
                • 8
                • northern ireland
                It's not a bios issue unless I'm not understanding you, and I don't have a 16 pin clip to get it
