Gamimg pc b450m ds3h board NO Video...Tried everytjing
  • irepair559
    • Dec 2022
    • 134
    Hello i gpt a b450m ds3h board with a ryzen 5 2600 no display..
    Tried Switching around ram, one stick, 2 other sticks from other pc..
    Tried CLR CMOS
    Another Video card
    Unplugging everything
    Flashed latest bios firmware manually ( took chip off board and flashed it with ch314 tool.)
    What else can i check ? how can i test cpu or board ?
  • irepair559
    • Dec 2022
    • 134
    Re: Gamimg pc NO Video...Tried everytjing
    anyone ?
    • stormanimal83
      • May 2014
      • 74
      Re: Gamimg pc b450m ds3h board NO Video...Tried everytjing
      would advice to try programming once more first with first version possible for your board for example with ver. 1.0 and not the latest...
      was lucky somtimes. im using same cheap tool as u. as long as u always verify the programm and dont forget that its impossible to go to download site of manufacturer loading files there and just writing them to the chip this tool is ok (slow but if u got time = no problem). this is not how its working.
      try google search for "dump´s" of the chip for your board otherwise.... if the hardware is ok u wil be lucky again then. as i said try first version always... upgrade is done easy....
      good luck
      • anikin73
        • Mar 2022
        • 112
        • singapore
        The power sequence led run like what sequence ?
        Do you feel cpu get heated up ?
        • irepair559
          • Dec 2022
          • 134
          was the board , repalced and all is good now. Thanks guys
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • Hakuu
            by Hakuu
            Hi There,
            More Details
            TV Model - LG OLED77G1PUA
            07-12-2023, 02:37 PM
