dell Optiplex gx280
  • iliiinieis
    • Jan 2007
    • 17
    #41
    Re: dell Optiplex gx280
    So if I have a couple of 1000uF6.3v then I can use them in place of the 820uF6.3's? Even if they are bigger or smaller than the originals? As long as they don't get in the way of course.
    • iliiinieis
      • Jan 2007
      • 17
      #42
      Ok guys, I am apparently too stupid to be allowed to live. Lol. I am not a cap expert but I am A+, N+ and MCSE certified. However no amount of education prevents me from screwing things up from time to time. I need another GX280 Motherbaord. Any ideas of where I can get one and cheap? I had just soldered the last cap onto the board. I dropped a Philips screwdriver into the LGA 775 socket and destroyed a bunch of the little pins. Why they took them of the CPU and integrated them into the board is beyond me but never the less, I still need a new board. I am assuming that replacing the socket itself would be a nightmare. Any ideas?
      • gonzo0815
        • Feb 2006
        • 1600
        #43
        Ha ha ha, you shure not followed any advice from the manufacturer: "remove the plastic cover only when isntalling a CPU"
        I hate this damn LGA soket, but ok there is no choice for us on this issue.
        • iliiinieis
          • Jan 2007
          • 17
          #44
          A big thanks go out to you guys and all your info as well as Chris at BC.net. Got one of them up and running! Runs great too!! Unfortunatley the other one me. LOL Waiting on a new Mobo from Hell. I mean Dell.
          • iliiinieis
            • Jan 2007
            • 17
            #45
            Hey guys, I called up Dell and it turns out that my warranty was some business gold package so they sent me a new motherboard to replace the one I messed up with the screwdriver. Lol. Oh and guess what, they have different caps already on them! No nichicon. The tech guy told me it was a huge problem with that cap manufacturer but that they got it under control now. Anyway, I don't need the caps now. I am happy.
            • jlrich14
              • Jan 2007
              #46
              Hey, I have a question and kinda am stuck. I received a GX280 from my friend who actually got Dell to send her a new MB and I cant figure out how to get this thing out. Its not like anything I'm used to, to be honest and was wondering if anyone could help me out. If anyone could, I would be greatly appreciative. Thanks JR
              • gobsgraham
                • May 2009
                #47
                Hey Guys, Bump of an old thread.
                I have two GX 280's that were given to me with all of the symptoms of bad caps but none of the nichion caps are swollen. Should I just replace them all anyways and hope it works. I don't really want to invest the $20 + an hour for no reason.
                What are your thoughts?
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  #48
                  gobsgraham; Welcome to badcaps and sorry no-one replied to you
                  I would think it is unlikely if the caps have not swollen, that is the most likely failure mode of the Nichicon caps...
                  Here is a model I recapped today, would only blink it's diag lights on the back after being on for like 5 mins to warm up, no POST at all, turned on off intermittently, I was infact very sceptic a recap would fix it
                  Seeing as only 8 caps where bad, the rest are Rubycon and Panasonic and they are all fine... Here are some nekkid pixx
                  Replaced the 3x 820uF 6.3v with Samxon GC 1000uF 6.3v.
                  And the 1500uF 6.3v by the PCI slots with matching Samxon GC...
                  After recap it purrs like a cat
                  POST directly without any issues!
                  Btw, if anyone has one of those slim floppy cables for this case, part no 7F455; I'd love to take it off your hands
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    ive made my own slim cables. find one of the right length, split the ribbon into smaller ribbons between the plugs (use a sharp knife and a steady hand), stack ribbons, zip tie the bundle and there you go, a floppy cable with the cable size of a SATA cable. post if you need a few pics of what ive done.
                    sigpic
                    (Insert witty quote here)
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      #50
                      ratdude747; not possible, this is a very special cable...
                      On the pic right to the text "FDD" is supposed to be a male FDD +5v connector, it's been stripped straight of the PCB, not easy to fix...
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        oh
                        why in the #@$% would they make it like that? stupid design.
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          is that a male or female plug? if female, find a dead power supply. cut off a floppy connector with the wires attached and solder that in there. if male, steal a plug off a dead floppy drive.
                          or search for "mini berg". thats the type of plug you need.
                          sigpic
                          • Wizard
                            • Mar 2008
                            • 2296
                            #53
                            Have stash of old 3.5" floppy drives? Find one with through hole power connector and take it and solder that one on. If the solder holes on other side are intact.
                            Cheers, Wizard
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              #54
                              No, as I said cable can't be repaired, the traces on the slim cable have all been ripped to hell
                              • Junk Parts
                                Court Jester
                                • Jun 2006
                                • 8953
                                I feel your pain Per Hansson! Its a Dell ! I'm going up to my friends shop today to get a good working DVD drive. I'll look for your part too. Lots of Dell guts around that place... If I find anything I will PM you.
                                "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
                                Mark Twain
                                "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
                                John Paul Jones
                                There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
                                Rod Serling
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  #56
                                  It's ok, Big Pope said he would be able to find one for me...
                                  But thank you for the offer!
                                  • jole1901
                                    • Sep 2012
                                    • Croatia
                                    #57
                                    Helo, can someone help me. I have motherboard Dell Optiplex GX280 SFF, I got it without some capacitor. Is missing the following capacitors, C461, C462, C463, C464, C465, C145, C139, C160, C161, C162, C163, C164, C165, C166, C167 and C150. If somebody can send the values of these capacitors was I would be very grateful. thanks
                                      DELL OptiPlex 3080 OptiPlex 3000 i5-10500T Specification for Upgrade or Repair
                                      This specification for the DELL OptiPlex 3080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3080 boardview and OptiPlex 3080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      09-12-2024, 02:30 PM
                                      DELL OptiPlex 7070 OptiPlex 7000 i5-8500 Specification for Upgrade or Repair
                                      This specification for the DELL OptiPlex 7070 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7070 boardview and OptiPlex 7070 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      09-12-2024, 03:44 PM
                                      DELL OptiPlex 3070 OptiPlex 3000 i5-9500 Specification for Upgrade or Repair
                                      This specification for the DELL OptiPlex 3070 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3070 boardview and OptiPlex 3070 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                      DELL OptiPlex 3070 OptiPlex 3000 i3-9100T Specification for Upgrade or Repair
                                      DELL OptiPlex 5070 OptiPlex 3000 i5-9500T Specification for Upgrade or Repair
                                      This specification for the DELL OptiPlex 5070 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 5070 boardview and OptiPlex 5070 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
