Vref very high on uP9512, any obvious cause?
  • willfg
    • Feb 2023
    I am currently working my way through fixing a Gigabyte Gaming OC RTX 3080.
    I managed to get the 1.8V rail working again but the controller for MSVDD does not seem to be working. It is getting and enable signal and 5V but not giving me PGOOD.
    I could be mistaken but Vref seems to be reading 4.5V when my understanding is that it should be around 2V. Has anyone seen this sort of symptom before and managed to work out whether it is a resistor / cap somewhere that is broken?
  • willfg
    • Feb 2023
    Re: Vref very high on uP9512, any obvious cause?
    Vref of 4.5 seems fine. Checking PGOOD not low due to overcurrent / short.
    • willfg
      • Feb 2023
      Nope, Vref should always be about 2V. Replaced controller and still at 4.5V. Seems unlikely new controller is also broken
        Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
        I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
        I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
        I tested the battery cells there are installed right now and they are testing good with no issues that I...
        02-04-2025, 08:08 PM
      • Grouickman
        Hofmann geodyna 6300 Wheel balancer
        by Grouickman
        Hi there,
        First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
        Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
        I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
        I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
        03-31-2025, 05:29 AM
      • DynaxSC
        Extreme High Current & Low Voltage Short Killer ??
        by DynaxSC
        Hi Folks
        I'm looking for a extreme high current short killer solution for a reasonable cost.
        I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
        After taking off the socket, the shorts dissappear again.
        The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
        10-15-2024, 10:13 AM
      • harp
        high voltage high resistance marking resistor
        by harp
        Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
        08-26-2024, 01:42 PM
      • ictc
        Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
        by ictc
        I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
        Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
        The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
        02-25-2025, 12:15 PM
