MSI X570-A PRO , I sin on the firmware, there is no initialization
  • skynet85
    • Jul 2015
    • 124
    • Georgia
    Hello, Merry Christmas everyone. MSI X570-A PRO , MS-7C37 ver:3.1 Stone RYZEN 9 3900X, after press PowerON starts, flash only led (DRAM) lights up. I sin on the firmware, flash MX25U25673GZ4I40 (MX25U25673G), but there are two problems: there is no bios file from the programer (there is an official one) and my programer does not support flash. Need advice on next steps. I'll post measurements later. Thank you
    • 21620
    Re: MSI X570-A PRO , I sin on the firmware, there is no initialization
    What model is your programmer and software version
    • Manabo
      • Jan 2023
      Any updates to this as i also need to flash this ic?! Thanks
      • cobovo
        • Jan 2023
        • 12
        • Ukraine
        Maybe use another flash that presents in support list your programmer but with the same parameters: Mbit and Mbyte
        • TheUser
          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
          by TheUser
          Hello to everyone ,
          This is my first post here, and i would like to share with you a small story in case you can help me.
          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
          02-10-2024, 02:07 PM
        • zklgfs
          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
          by zklgfs
          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
          08-11-2025, 02:14 PM
        • gurj1979
          Ubiquiti firmware help. US-8-150W POE
          by gurj1979
          Hi guys.
          I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
          Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
          So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
          Got New chip and writes good.
          THE PROBLEM...
          It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
          Does anyone have a Good Firmware I can have?...
          07-22-2024, 05:13 PM
        • wattage
          by wattage
          Hello Badcaps Community,
          07-13-2025, 04:41 PM
        • sikocan
          NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
          by sikocan
          I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
          However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
          01-11-2024, 01:47 AM
