I need Huawei router hg531s bios
Re: Huawei router hg531s bios
there is no original firmware, it's only sold to isp's who put their own crap on it.
every isp is going to be different and there is no "factory" firmware.
now if you have the patience to open it and compare it to other models sold to the public you may find a match
then you can go look here:
https://openwrt.org/toh/startComment
by AhariHi all,
I...-
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by macabookHello everyone,
Iβm currently working on a dead MSI GP75 Leopard (MS-17E71) motherboard (i7 CPU, NVIDIA GPU) with a no display/no backlight issue initially. After extensive investigation, Iβm at a critical stage involving EC firmware, BIOS/ME region interaction, and possible deep corruption. I'm seeking advanced insight from anyone with experience in EC/BIOS sync issues or PCH-level behavior. Hereβs a full breakdown:
π§© Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM - Loading...
