My wireless woes
+ More Options
Posts
  • stevo1210
    • Oct 2006
    • 4156
    My wireless woes
    I have this problem with my wireless and its driving me insane. Basically, my WRT54G Linksys router isn't being picked up by some of my PCs, unless I refresh the WZC wizard a few times in Windows. What's wrong here?
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • seanc
    • Nov 2008
    • 1319
    Re: My wireless woes
    What's the history of the router? Any recaps? Checked out the insides?
    • retiredcaps
      • Apr 2010
      • 9271
      Did you check or enable
      "Connect if the network is not broadcasting"
      http://www.windowsreference.com/wind...dcasting-ssid/
      --- begin sig file ---
      --- end sig file ---
      • stevo1210
        • Oct 2006
        • 4156
        The router is still under its 3 year warranty, so I haven't recapped it. But it's done this since the day I got it.
        • retiredcaps
          • Apr 2010
          • 9271
          Are you running the latest Linksys firmware or some variation like Tomato or DD-WRT?
          • stevo1210
            • Oct 2006
            • 4156
            Not the latest firrmware... I haven't updated it since the day I got it... maybe I should give that a try.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              the wrt54g series are much nicer once flashed with tomato or dd-wrt.
              the caps usually give a year of service before the unit goes unstable.the new shiny curvy ones that replaced these even shorter.
              • retiredcaps
                • Apr 2010
                • 9271
                Even though Linksys is owned by Cisco,it is run as a separate division/business so that means that the Linksys home/consumer products only get about 1 major revision (and some minor fixes) of code. This code lasts about 18 to 24 months and then there are no more updates.
                This is the same for all major home routers link Dlink, Belkin, etc because of the low gross margins these products make.
                By going to latest Linksys version or third party you get the latest patches and bug fixes. You may want to consider tomato or dd-wrt because they "regularly" get updated with new features and bug fixes from the software development community.
                When you update firmware, pay close attention to what hardware revision your router is. Depending on the hardware revision (usually a sticker on the underside of the router), you may be restricted by what you can run because of the amount of flash memory in the router.
                In a way, upgrading firmware to the latest is like recapping to all new caps, but without the expense of buying new caps or soldering.
                Even though I'm a newbie on this board and to caps, I have been in the network field since 1989 (started with Novell Netware 2.11 and Arcnet).
                PS. You never did answer if your windows clients are set to "Connect if the network is not broadcasting". Also, some software on the routers default to NO broadcast SSID for "security purposes".
                PPS. I have an older Linksys 802.11b router and it is still running on the original caps. I only upgraded to 802.11g because I got a good deal on a used router off kijiji. I would try the firmware upgrade first and check your clients (as per above) before even thinking about a hardware issue.
                • NxB
                  • Feb 2009
                  • 1595
                  dd-wrt for the win. I have 2 of them up now and they are fairly stable. One was ditched by a commercial client because it kept dropping the connection. Once flashed it does this no longer.
                  • seanc
                    • Nov 2008
                    • 1319
                    Think I'll try dd-wrt on mine. I'm not using it, because it's picky about when it will power up - sometimes it will just light the power led dimly.
                    I've recapped it and tried a different PSU, same thing, unless I missed a cap.
                    As long as it powers up and doesn't die once it's up, it should be OK.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Post pics of motherboard and backside.
                      I doubt dd-wrt will help because this sounds more like a hardware issue.
                      Did you replace all the caps?
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        One other thing to check is to see if the DC jack is loose or not.
                        I have a Motorola cable modem which I would disconnect from the DC jack side whenever it was not in use. Eventually over the years I probably stressed the DC jack and now it only works if you wiggle it. Once it is on, it stays on.
                        Also check for solder cracks/joints/rings on the motherboard.
                        • seanc
                          • Nov 2008
                          • 1319
                          Yeah I had re-capped it - forgot to mention that, doh.
                          Just opened it up to see what I'd put in, found I'd put one non low ESR 220uf 25v panasonic NHG in, just replaced it for an FM - seems fine at the moment. The others are panasonic FC 100uf 16v
                          • seanc
                            • Nov 2008
                            • 1319
                            No dd-wrt or Tomato for me, I have a v7. I suspect Stevo is in the same position.
                            • NxB
                              • Feb 2009
                              • 1595
                              I have run the micro versions too. I have a v6 and a TM (mega version). Also add the extra caps that they left off.
                              • pfrcom
                                Oldbie
                                • Jun 2006
                                • 1230
                                Check out Windows event viewer - system
                                Had a client system which wouldn't connect, showed weirdo network events, plus problems with their disk
                                Not worth trying to build when the foundation is shaky
                                better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                                • shadow
                                  • Feb 2007
                                  • 732
                                  I love my good ol' WRT54GS...it is very old now (can't even remember when I got it ). However it has been rock solid for years and years now even with the original crap caps. Maybe one day I will recap it .
                                  Originally I used HyperWRT by Thibor firmware. It was quite nice, essentially the stock firmware but with a few fixes and small additions here and there. However it seems like support for that firmware has ceased. I then moved onto Tomato firmware...loved it. I then tried Victek's Tomato RAF...this was just perfect for me. It is essentially the original Tomato firmware but with a few tweaks and additions here and there. I have had some interest in VPN lately. So I have just installed and setup TomatoVPN. Pretty neat how I can runa VPN server directly on a cheap router. Have not done much with it so far so I can not judge how good it is. However it is working fine and is stable.
                                  • japlytic
                                    • Oct 2005
                                    • 2086
                                    Firmware updates are important to enable the latest security features.
                                    I had a D-Link DIR-524 which had hardware support for AES and WPA2, but was not implemented in the firmware. An official firmware update enabled AES and WPA2. Also, I have a Linksys WRT55AG which supports WPA with AES (but not WPA2) - the majority of non-WPA2 routers others have hardware support for AES, but is not enabled in the firmware .
                                    Turning off SSID broadcast can cause interference to all wireless networks (including yours) if they all happen to use the same channel, so many leave SSID broadcast on, to make finding their wireless network easy, especially in some buildings with 'dead spots'. As I said elsewhere, I only turn off SSID broadcast if it is in a corporate environment.
                                    • NxB
                                      • Feb 2009
                                      • 1595
                                      SSID broadcast off doesn't do squat. You can still scan and pick the AP up with site survey tools.
                                      Neither does mac authentication if you use any clients at all.
                                      • double_DD
                                        Why does my ISP router hate my "homemade" power supply??
                                        by double_DD
                                        It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                        So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                        For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                        Today, 03:09 AM
                                        HP EliteBook 840 G6 + Backpack & Wireless Premium Mouse Notebook 800 Specification for Upgrade or Repair
                                        This specification for the HP EliteBook 840 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Backpack & Wireless Premium Mouse boardview and 840 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                        09-06-2024, 03:30 PM
                                        HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
                                        This specification for the HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + Backpack & Wireless Premium Mouse boardview and 640 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                        HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook 400 Specification for Upgrade or Repair
                                        This specification for the HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Backpack & Wireless Premium Mouse boardview and 430 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
