Netgear DG834GT The Little Router That Could
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    This is a small router I've both hated and loved
    Story goes a friend called me some years ago and asked what router to buy, I had read good things about the DG834GT back then (this was just when it was released)
    So I advised him to buy it
    Now a compatibility problem with his ISP's DSLAM caused it unable to get an IP Address, I first brought it up with Netgear and they where very responsive, sending me unreleased BETA firmwares and so on, but it did not help
    So I hacked the router myself, compiled a new firmware for it with a more recent dhcp client, hoping that would allow it to get an IP, but it did not, in the process that also caused a problem in that the firmware could after that not be flashed via the webinterface, so I had to connect it up internally via RS422 serial to flash directly from the CFE...
    So for every subsequent upgrade of the routers firmware I had to bring out my Linux Compilation toolchain for the DG834GT and compile it just so I could get the firmware that the CFE flash needed...
    After a while a firmware that did work with Ericssons DSLAM's was released
    But not by Netgear but instead a guy like me that got hold of a more recent ADSL driver for the router... The name of that firmware was UberGT
    That worked really well and he ran it with that for about 2 or 3 years now
    Out of boredom (and because of my 4 weeks vacation) I decided to give it another go, because the old UberGT project was cancelled due to an even more capable firmware being released by a project called DGTeam.
    I was not able to flash the firmware with the webinterface but could use the recovery utility with the excellent instructions on this page, so no need to start compiling stuff again
    After installing the firmware and starting the router up again there was allot of more settings offered by the new firmware.
    I ran some performance tests and while maxing a 24mbps ADSL line (synced at 23mbps down and 2.3mbps up) downloading linux ISO files with µTorrent, loads where generally acceptable below 1.0
    But the interface did feel quite slow, and I did get disconnected via telnet a few times when checking loads and RAM usage, the download speed was not affected tho...
    Anyway I left the router be but next day he called me and said the router was really hot, so I thought either the new firmware had a bug causing 100% CPU load (which I did not notice when I was there because idle it's load average was like 0.01) or it was "the other problem"
    So I asked him to bring it over and sure enough;
    One of the 2x TEAPO SC 1000uF 16v caps had vented, replaced them with Samxon GD 2200uF 16v caps, did not have more suitable caps in stock though I'm sure the extra bulk capacitance will just be good
    There was 1x TEAPO SC 1000uF 6.3v cap, this I replaced with Samxon GC 1000uF 6.3v
    And 1x TEAPO 470uF 16v replaced with Samxon GC 470uF 16v
    The lone capacitor on the right of the PCB is a UCC and still had good ESR so I left it in place
    After this I did a new performance test, downloading the same linux ISO so maxing the router, also surfing and listening to webradio at the same time
    The router held up good, no disconnects on Telnet and load seemed to be lower (around 0.5 instead of 1.0)
    So I guess it does make a performance difference to have caps that are actually able to filter the current for the processor
    Last edited by Per Hansson; 05-11-2014, 08:29 AM. Reason: Offsite images uploaded due to problems with host
  • c_hegge
    • Sep 2009
    • 5219
    Re: Netgear DG834GT The Little Router That Could
    I have a very similar router (netgear DG834G v3) with very similar caps. They were all cheapo teapo. I've Just finished re-capping it now and am using it 4 this post. Caps as follows:
    3x Teapo SY 1000uF 16v -> Panny FL
    1x Teapo SY 470uF 6.3v -> Sanyo WG
    1x Teapo ?? 100uF 25v -> Rubycon YXF (maybe not the ideal series but better than a failed teapo)
    I only had a 16V for the Ruby YXF, but I checked the voltage before the re-cap and it was only 12v, so it should be fine.
    • japlytic
      • Oct 2005
      • 2086
      There were 5 Teapo SY Series units in mine (DG834GSP v3); the rest of the electrolytics were Nippon Chemi-Con KY Series.
      The three 1000uF 16V units were immediately after the DC input jack (no need to replace), but a 470uF 16V (+3.3V rail) and a 100uF 25V (+12V rail) were replaced with Nippon Chemi-Con KY Series units.
      • EasyGoing1
        UPNP, "Standards" and hardware that implements it
        by EasyGoing1
        I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
        One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
        So I decided to implement UPNP...
        07-16-2022, 07:12 PM
      • filippia1981
        Starlink WiFi router firmware of the HR1211 IC
        by filippia1981
        Hi, I would like to ask if someone has the firmware of the HR1211 IC of the Starlink WiFi router in order to program a new IC
        The diagnosis showed that this IC is shorted and need to be replaced with the right firmware. I cannot find the firmware
        kind regards
        Ioannis Balouktsis
        06-17-2024, 11:38 AM
      • ay_erdi
        Netgear R7500 Router Dead
        by ay_erdi
        Hi everybody,
        My router netgear R7500 is dead.There are four burnt components inside.Can you help me identify?
        VR8-U17-U78...
        02-16-2024, 10:58 AM
      • TheUser
        Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
        by TheUser
        Hello to everyone ,
        This is my first post here, and i would like to share with you a small story in case you can help me.
        Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
        All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
        I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
        02-10-2024, 02:07 PM
      • zklgfs
        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
        by zklgfs
        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
        08-11-2025, 02:14 PM
