multiple domain setup with one VPS and cPanel
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    The new business is moving along real fast now, and it's time to setup the domains.
    I've registered both, let's call them mybusiness.com and mybusiness.net
    I also have my first domain, mypersonaldomain.com.
    I wanted mybusiness.com and mybusiness.net ran under my wife's name, instead of being ran by me, like mypersonaldomain.com is.
    I want it so mybusiness.com and mybusiness.net point to the same location on the VPS.
    We use cPanel. I created an account for my wife and created the domain mybusiness.com. The registar has the nameservers setup as ns1.mypersonaldomain.com and ns2.mypersonaldomain.com.
    1) Should the two new domains have their own ns1 and ns2 DNS entry?
    2) How do I go about creating the second mybusiness.net domain, and having it point to the same physical directory that mybusiness.com points to? I tried creating an add-on domain, but that appears to just create a subdomain, which isn't what we want.
    All three domains are currently running on the same VPS.
    I also asked this on the cPanel forums, which I know is generally not a good idea, asking on multiple websites the same question. But our E3 licenses are live now, and because we're going through the CSP, we'd rather have our login names on the local machines as Spork@mybusiness.com or Spork@mybusiness.net, rather than Spork@mybusiness.onmicrosoft.com
    Our business name is fairly long.
    Any cPanel / network experts out there?
    Thanks!
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • diif
    • Feb 2014
    • 6978
    • England
    Re: multiple domain setup with one VPS and cPanel
    So you want to redirect one URL to another ?
    • Spork Schivago
      • Mar 2012
      • 4734
      Yes, if that's the best way to do it. I was thinking of just manually editing the DNS zone...what do you think? The other option would be to somehow try and find away to create a domain without a user, and then assign Jess to that other domain....
      If I use something like redirection, how would SSL work? I'm using AutoSSL, where Apache needs to have a documentroot directive set, and then it tries to write a file there and read it. If they can't do it, it fails and won't create the SSL cert.
      If I'm just redirecting (using maybe an apache redirect statement or something), if the first site that they go to, that redirects to the second, doesn't have an SSL cert, but the second site does have one, will a browser throw a fit?
      Spork
      • RJARRRPCGP
        • Jul 2004
        • 6301
        Pale Moon probably will yell at folks! Likely with the given reason being that the cert is only for one of the other domains. Pale Moon likely will yell about an invalid cert domain.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • diif
          • Feb 2014
          • 6978
          • England
          There should be an option in cPanel called URL redirect.
          • Spork Schivago
            • Mar 2012
            • 4734
            There is, but I need to somehow create the domain in cPanel / WHM without creating yet another user....that's the issue I can't figure out. Do I just create an add-on (sub-domain) domain and then use the redirect in WHM?
            • Spork Schivago
              • Mar 2012
              • 4734
              I finally got the domain setup. Now I'm really pissed. Gonna kill someone.
              • diif
                • Feb 2014
                • 6978
                • England
                Why ?
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  Microsoft reseller, who is an actual Microsoft employer who works at Insight lied I think.
                  He said for the workstation, my copy of Vista Ultimate Retail would be a qualifying OS. But according to the Microsoft Documents and the Microsoft support team through the CSP portal, I need 7 Pro Retail or higher and Vista won't work.
                  He also said for the VMs, I don't need any OSes, I can just install Windows 10 Enterprise E3 VDA, no product keys required. It seems that was a lie. So now I need three more copies of probably Windows 10 Pro, plus one for the workstation. 200$ a pop, that's 800$. Bastard.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    A salesman talking bullshit ? That's never happened before....
                    You should have asked him to confirm in an email what he was saying.
                    Or done it as I would have done as per PM. Microsoft hasn't got as big as they are by being cheap.
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      I was trying to communicate with him via email! Just so I'd have a copy of what he said, but he kept on saying it'd be too complicated to do over email and we just needed to do a conference call. But maybe he didn't lie and I'm just configuring 10 Enterprise E3 wrong? I dunno. Maybe I'm supposed to use KMS activation or something and point it to the CSP portal?? Every document seems to say I need a qualifying OS installed on the machine or even on the VM in order to upgrade to 10 Enterprise.
                      • Modify_inc
                        Locked Setup Fails to Unlock with Correct Password - Inspiron 11 3185
                        by Modify_inc
                        I have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
                        11-02-2021, 11:14 AM
                      • Msb1xr
                        Have to turn on 77” LG C1 multiple times to get to come on
                        by Msb1xr
                        Have to turn C1 on and off multiple times for it to fully come on
                        Have to run LG C1 on multiple times for it to fully work
                        If I have it off for a while I have to turn the TV on and off and handful of times for it actually display what it's suppose. The times it doesn't nothing comes up like the input or dobly vision logo. Once it's on I can turn it off and back on fine and the picture looks perfect.
                        Unhooked everything except antenna. Reset tv to factory settings. Let it sit and when I tried 2hrs later turned TV on and sound comes through but no picture....
                        10-13-2023, 04:09 PM
                      • nicktasios
                        Troubleshooting Apple Multiple Scan 17 Display
                        by nicktasios
                        I recently picked up a Quadra with a Apple Multiple Scan 17 Display. The Quadra was not working, it clearly had corrosion from leaking caps so I replaced them and luckily it chimed and worked properly.
                        The next problem to tackle was the screen. Sometimes it turns on and off multiple times before finally turning on, and then it sometimes turns purple. After waiting some time, without doing anything, it regains all colors. Another symptom is that it sometimes seems to momentarily blink.
                        Also, not sure if this is related, but sometimes, after experiencing these problems,...
                        09-17-2023, 03:51 AM
                      • notallbad
                        Samsung UE55JU6000K stuck at 'Setup Conplete'
                        by notallbad
                        Reset the tv as internet connection not working, connected to router but no internet.
                        Did a factory reset and completed the initial setup process but now just freezes on 'Setup Complete' page.
                        Going into service menu it says 'Failure' at the top of the page and unable to access the 'control' screen.
                        Its already on T-HKM6DEUC1570.0 fw.
                        Are the SVC reset options likely to help here?
                        options are
                        apps reset
                        svc reset
                        spi flash reset
                        data sync reset
                        Any help appreciated.
                        08-26-2023, 10:44 AM
                      • remizbushka
                        Dell inspirion 5775 bios "Unlock Setup fail"
                        by remizbushka
                        Hi sirs. please help
                        Dell Inspiron 5775 bios locked "Unlock Setup fail"
                        After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
                        What I did:
                        I read the bios dump.
                        Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
                        03-24-2025, 09:07 AM
