Buffalo vs TP-Link for 16 port switch
  • cruzinforit
    Rin is my waifu
    • Apr 2015
    • 22
    I'm going to be moving into a new house with several friends, and I'm in charge of overhauling the (non)existing network setup. Currently it's simply the Time Warner provided modem with built in wireless. In a 115 year old home, it is completely inadequate in every way.
    I am bringing in my pfsense router/firewall, and TP-Link Archer C5 AP with 9dbi antennas. But in the process, we are going to need a 16 port switch to handle all the wired devices. I have narrowed it down to either the below Buffalo switch, or the following TP-Link one. The Buffalo is unmanaged, the TP-Link non-rackmount is a "smart managed switch". I don't really care much about the smart aspect, a dumb switch would be fine here.
    For the price difference, is there any reason to go with the TP-link over the Buffalo?
    http://www.amazon.com/gp/product/B00...f_rd_i=desktop
  • japlytic
    • Oct 2005
    • 2086
    Re: Buffalo vs TP-Link for 16 port switch
    In our place (with 14 network ports wired in during construction - the study has four ports, with the living room, home theatre room and two bedrooms have two ports each, along with the master bedroom and garage having only one), we use a 16-port unmanaged Gigabit switch with the wireless router (DHCP server) assigning the LAN IP addresses.
    Note that one of the ports on the network switch is used for connection to the wireless router.
      • 31015
      the tp-link is probably worth the extra for the cable diagnostics feature.
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
      • Natob82
        Micro Momentary Push Switch?
        by Natob82
        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
        12-21-2022, 05:22 AM
      • CapLeaker
        Poly VVX-250 VOIP POE problem not booting fix
        by CapLeaker
        I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
        Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
        11-25-2023, 10:46 AM
      • grimacelord
        NEC TurboExpress On/Off Power Switch Replacement Help
        by grimacelord
        I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
        I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
        I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
        11-09-2023, 09:49 AM
      • SluggerB
        Help making a switch work the opposite way with a relay
        by SluggerB
        I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
        I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
        It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
        02-07-2025, 07:57 PM
