Big network troubles
+ More Options
Posts
  • blasterboomer
    • Dec 2013
    • 135
    Hi, i run a Minecraft server and website from home, which is at www.campcobble.co.uk The problem is that i recently got a wd my cloud 3tb and when going to the website it brings up the wd my cloud web panel, even though no ports are open to the wd my cloud at all and its running on a different ip (192.168.0.100) whereas the webserver is on 192.168.0.2. I know the wd my cloud runs apache because i can ssh into it. any help please?
    If you need any other info just ask
  • blasterboomer
    • Dec 2013
    • 135
    Re: Big network troubles
    UPDATE: I changed the port from 80 to 8200 and its changed because i now need to use 192.168.0.100:8200 to get the web panel. But website still trying to lead to /UI even though the ports are correct and the web server is a completely different device
      • 30952
      are you saying he outside world isseeing thw wd insteadof another host machine?
      if you are then go fixed ip (kill any dhcp server) then use port forwarding on the router.
      • blasterboomer
        • Dec 2013
        • 135
        using the external ip it is going to the wd even though no ports are open for it... and i cant really test anymore since i got my friend to go over and replug the ethernet cable and he put it in the other ethernet port which does not work (sigh)
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          see if your network has plug-n-play enabled, P&P devices will tell the router to port forward
            • 30952
            UPNP is a security risk that should always be disabled!!!
            • diif
              • Feb 2014
              • 6978
              • England
              Does sound like you have UPnP enabled.
              As stj says, it needs disabling and your port forwarding setring up.
              Check you have the latest firmware on your mycloud, a customer of mine bough one recently and there is a recent security update.
              • Mad_Professor
                A Mech Warrior
                • Feb 2011
                • 1587
                I agree with the others, UPNP is enabled. Disable UPNP, then port forward 80 to your webserver nat ip and port forward the minecraft ports to it's respective nat ip.
                You should be good to go after that.
                • blasterboomer
                  • Dec 2013
                  • 135
                  how do i disable upnp on a sky hub? its so locked down... also the wd my cloud has been modified to use port 8200 (latest firmware)
                  • blasterboomer
                    • Dec 2013
                    • 135
                    nvm i found upnp and disabled it... im gonna reboot the hub and webserver and il report back on what happens...
                    UPDATE: still not working... although its not showing the wd my cloud page anymore... one thing i found strange though, when i ping 192.168.0.3 (webserver internal ip) it loses some packets... should i purchase a new ethernet cable or could the lost packets be another issue
                    • Mad_Professor
                      A Mech Warrior
                      • Feb 2011
                      • 1587
                      You might need to check firewall rules or port forwarding rules, you might need to reboot the webserver or at least reload the network service if you're running linux.
                        • 30952
                        inspect the cable for damage and try another socket on the shit sky router.
                        • blasterboomer
                          • Dec 2013
                          • 135
                          Im getting a new router... its http://www.maplin.co.uk/p/asus-n900-...l-router-a84nc because the sky hub is total shit.... ive already extracted the username and pass using wireshark so this should work... and im installing another ethernet cable too
                            • 30952
                            maplin is not the cheapest place these days, you should check ebuyer.
                            http://www.ebuyer.com/
                            • blasterboomer
                              • Dec 2013
                              • 135
                              ok, i got the asus router today... and im waiting for my ehernet cable and wall boxes to arrive... anyways the router works great... but im concerned about the CRC on the up and down... is this normal?
                              also im thinking of getting sky fibre pro which is 72mbps down and up to 19mbps up... but its saying my max is not even close to what sky fibre pro would be... so is there no point upgrading to pro?
                              • SteveNielsen
                                Retired Tech
                                • Jun 2012
                                • 2327
                                It is not unusual for errors to occur during link negotiation, like at bootup or hot connecting. If they aren't increasing over time they probably aren't a concern.
                                • blasterboomer
                                  • Dec 2013
                                  • 135
                                  This is it now
                                    • 30952
                                    line attenuation ? is that ajustable?
                                    btw, VDSL - where is the fibre interface, on the wall outside your house?
                                    i'd look at BT / OpenReach (or subcontractor fucks like kelly's) work to check the wiring is good.
                                      • 30952
                                      and maybe ask here:
                                      http://www.kitz.co.uk/
                                      • blasterboomer
                                        • Dec 2013
                                        • 135
                                        i can adjust the line attenuation etc but ive left it set as 0... the speeds are identical to what the crappy sky hub gave me
                                        • Rozp
                                          70LE660U dark cloud or black screen with sound.
                                          by Rozp
                                          Hello Everyone,
                                          This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                                          I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                                          08-29-2023, 05:25 PM
                                        • omega
                                          Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                                          by omega
                                          Hello all,
                                          as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                                          Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                                          02-09-2024, 03:34 PM
                                          HP EliteBook 840 G6 + Qnap 2-Bay Personal Cloud NAS Enclosure Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G6 + Qnap 2-Bay Personal Cloud NAS Enclosure Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Qnap 2-Bay Personal Cloud NAS Enclosure boardview and 840 G6 + Qnap 2-Bay Personal Cloud NAS Enclosure schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          09-06-2024, 07:50 PM
                                        • davg
                                          Home network connection problem
                                          by davg
                                          I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                                          03-06-2021, 07:13 AM
