Hello everyone, i got this Tenda AC1200 SMART DUAL-BAND WIFI ROUTER, the problem is my electricity went off while the router was updating so it never worked, so i tired a firmware dump, it worked but the wi-fi won't appear, please help
Tenda AC1200 wifi not appearing
by filippia1981Hi, I would like to ask if someone has the firmware of the HR1211 IC of the Starlink WiFi router in order to program a new IC
The diagnosis showed that this IC is shorted and need to be replaced with the right firmware. I cannot find the firmware
kind regards
Ioannis Balouktsis-
Channel: Troubleshooting & Designing Networks
by howardc64Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
- TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
- Service Menu shows many Bt/Wifi info missing
- Vizio app shows no WIFIVendor file
- Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
by double_DDHi all,
It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,... -
by ugamazingI've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect... -
by AlexVGHi,
I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
(This board does not respond, only the LEDs light up in a circle.
The liquid damage is catastrophic and restoration is impractical).
(I bought this board to get the WiFi module and camera).
The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
If... - Loading...
