I need firmware for D-Link dsl-2750u
  • jrbrassow
    Need Public Firmware: TPV/Philips 86-inch Commercial Display (Mainboard 715GD081-M0F) - Stuck in Corporate Mode
    by jrbrassow
    Hello all,
    I am attempting to convert an 86-inch commercial display, manufactured by TPV, back into a standard, fully functional TV/monitor. The display is currently running corporate/embedded firmware that prevents standard operation.
    The primary goal is to find the original or a compatible "public" (non-corporate) firmware file to flash the mainboard and restore normal HDMI input functionality. 1. Display Identification & Hardware Details
    • Suspected Origin: TPV / Philips Professional Q-Line or P-Line series.
    • Panel HWID (from Windows): MONITOR\MGF86
    Yesterday, 01:57 PM
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
  • gurj1979
    Ubiquiti firmware help. US-8-150W POE
    by gurj1979
    Hi guys.
    I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
    Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
    So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
    Got New chip and writes good.
    THE PROBLEM...
    It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
    Does anyone have a Good Firmware I can have?...
    07-22-2024, 05:13 PM
  • wattage
    by wattage
    Hello Badcaps Community,
    07-13-2025, 04:41 PM
