My ATA PAP2T-NA Adapter Bricked, I want to fix
  • tester2
    • Sep 2012
    • 28
    • ca
    hi guys i need your help, i got PAP2T-NA which is not working, just hang on 2 Lights on it 1 is Red & 1 is Green.
    So i like to know how to fix this PAP2T.
    I am attaching Photo, please have a look.
    As well as I attach the Picture of PAP2T Motherboard.
    Hopefully waiting for your reply
  • nitelite
    • Apr 2013
    • 11
    Re: My ATA PAP2T-NA Adapter Bricked, I want to fix
    I have repaired a pap2 but it is a different revision than yours. https://www.badcaps.net/forum/showthread.php?t=29433
    Mine had a bad transistor that I found by plugging the board in and touching components one at a time till I found one that was hot to the touch. Using an ohm meter I confirmed the failed component. See my thread for the readings.
    • tester2
      • Sep 2012
      • 28
      • ca
      hi there, i apparicate for your reply.
      do you think my board having same issue, or on my board a CHIP which hold software having poor soldaring, i even don't know where is the CHIP on this Board & where is Q156 located.
      And you board having issue about "Loude Static", but my board having diffrent issue, i think my board having issue of loading software while rebooting PAP2T, so it is showing 1 Red & 1Green Light.
      • shortchange
        • Jan 2012
        • 27
        Still repairing?
        • tester2
          • Sep 2012
          • 28
          • ca
          hi guys, sorry for the delay, because i order "Soldaring Rework station smd 898D",
          So i resolder the above as shown in Post#4, still I am having same light are ON. As well as I did HOTAIR Flow over the Chip also, still same 1 red & i green light ON.
          So i like to know "How to check which component is Damage on the Board",
          Can any body let me know the procedure to check Component on the Board, then i will check one by one.
          • tester2
            • Sep 2012
            • 28
            • ca
            hi guys, i am still trying to fix this PAP2T, any help appricated.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Check U11 and U12 to see if they are good. If you are not sure how to check them, then tell us what numbers/letters are written on them?
              They are most likely voltage regulators ... transistors are marked with a 'Q'; integrated circuits with 'IC' or 'U'.
              Muh-soggy-knee
              • tester2
                • Sep 2012
                • 28
                • ca
                hi there, please let me know, by using multimeter RED Wire led & BLACK Wire led where i have to touch on U11 & U12 pins.
                And on which reading I have to adjust my Multimeter Pointer for example 2000K etc. I am having exactly same this Multimeter.
                I already saw U11 & U12 on my Board.
                Please how to check this is good or Bad, then i will check and post my result.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Ok, that is what I thought. Yes I can tell you where to measure them, but you have to tell us what the part numbers are on U11 and U12 ... the pictures aren't good enough to see the part numbers.
                  Muh-soggy-knee
                  • tester2
                    • Sep 2012
                    • 28
                    • ca
                    hi there, here it is the part numbers
                    U11 -- AMC1117, F0823J
                    U12 -- AMC1117, F0823J
                    both of them having same part numbers, i look very carefull, there is no mistake in part numbers, i use a lense which is use to fix WATCHES, so i put board close to my eyes and i read with lenses clearly.
                    When I order SMD REWORK STATION i order this Glasses also, so i have all the instruments to check the BAD parts.
                    • fixitdaz
                      • Jun 2013
                      sorry to read you purchased a 898D rework station,we had the hot air gun transistor fail and put power on to the element (Failed closed) causing the hot air gun to overheat and melt this is the video we made after the event.
                      • tester2
                        • Sep 2012
                        • 28
                        • ca
                        hi there i am still waiting to know "how to check U11 & U12"
                        thanks
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          thanks
                          Yes yes, patience! I didn't get home 'till late last night, and I was tired... sooo, yeah.
                          Ok, this is the pinout for the AMC1117's
                          http://www.seekic.com/uploadfile/ic-...5991839498.jpg
                          Find a spot that is connected to ground on the PCB and connect your black probe to there, then measure the voltage at the input and output pins of both regulators. Report back your readings!
                          Just a note ... the pin in that image which is marked 'ADJ/GND' .... don't use it as a ground point! It is likely not connected to ground, instead it is probably connected to a resistor divider to set the output voltage!
                          Muh-soggy-knee
                          • tester2
                            • Sep 2012
                            • 28
                            • ca
                            Please make me correct in the pictures
                            Picture 1 & 2 where i mark, that is same pin, can i use that for GROUND purpose.
                            Picture 3 & 4 where i mark, can i assume that is Pin2 (V out) & Pin3 (V in).
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Picture 1 & 2 where i mark, can i use that for GROUND purpose.
                              Yep, Looks like you have got it right! :P
                              Now, what are the voltages?
                              Muh-soggy-knee
                              • tester2
                                • Sep 2012
                                • 28
                                • ca
                                on my Multimeter, where i have to Adjust in VDC, please let me know. Can i Adjust 20V DC.
                                UPDATE :
                                I Power ON PAP2T then i touch Black Probe to GROUND & Red Probe to Pin 2 & 3 on both IC's, there is no reading shows. it shows just 0.00.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  UPDATE :
                                  I Power ON PAP2T then i touch Black Probe to GROUND & Red Probe to Pin 1 & 2 on both IC's, there is no reading shows. it shows just 0.00.
                                  Well that 'ground' point you marked may not be ground. Try measuring the voltage with the black probe on the negative of one of the electrolytic capacitors.
                                  Muh-soggy-knee
                                  • tester2
                                    • Sep 2012
                                    • 28
                                    • ca
                                    I don't know which one is the Electrolyte Capacitors. So i use the one which you mark for GROUND on IC that is PIN1 then i got readings below
                                    U11 -- Pin2 : 0.76, Pin3 : 1.66,
                                    U12 -- Pin2 : 0.63, Pin3 : 1.53,
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      The electrolytic capacitors are the cylindrical things with a shiny metal top. They have a strip on one side, that is the negative side. The pin on the bottom which is closer to the stripe is the negative pin.
                                      Muh-soggy-knee
                                      • tester2
                                        • Sep 2012
                                        • 28
                                        • ca
                                        When i touch Black Probe on Electrolyte Capacitor of Negative Pin then Red probe on IC Pins
                                        U11 -- Pin2 : 1.71, Pin3 : 2.60,
                                        U12 -- Pin2 : 0.95, Pin3 : 1.84,
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                          Fujitsu LIFEBOOK U939 Notebook U Specification for Upgrade or Repair
                                          This specification for the Fujitsu LIFEBOOK U939 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the U939 boardview and U939 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Fujitsu LIFEBOOK...
                                          09-06-2024, 09:40 AM
                                          Fujitsu LIFEBOOK U939X Hybrid (2-in-1) U Specification for Upgrade or Repair
                                          This specification for the Fujitsu LIFEBOOK U939X Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the U939X boardview and U939X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Fujitsu...
