Some routers have parental controls, but none seem to have a temporary override function for a particular website (why can't they implement this function?), but they have an "always override" list.
No temporary override function for parental controls on router?
My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Tags: None -
Re: No temporary override function for parental controls on router?
Probably because they have little memory, it would involve extra processing and because in order to do the "temporary" part they would have to add an accurate time source inside with backup power (if you want the site to be allowed for an hour, the router would have to keep time even if there are power failures and so on)
I guess you could do it with some custom firmware.. -
i need a router to do that it wold need a clock system but a battery?Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
by double_DDHi all,
It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,... -
by sam_sam_samThis is a new item at Electronic GoldMine that has arrived within the last few weeks
Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
https://theelectronicgoldmine.com/products/g28392
One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...11-24-2024, 01:25 AM -
Hello everyone, I'm troubleshooting an MSI Delta 15 (MS-15CK1) motherboard, and I need help identifying the function of the two coils marked in the attached image. The laptop powers on and responds to the keyboard, but the screen does not turn on-neither the LCD nor the backlight. I've checked the main power rails, and all other coils seem to have the expected voltages:
• 0.91V for the GPU
• 1.7V for VRAM
• 3.3V and 5V rails 1.8V for the BIOS
• 0.9V for the CPU and iGPU 1.2V for the RAM
However, these two coils are not showing any voltage....1 Photo -
by shadow666hello
i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
Mi Router 4A Gigabit Edition
ROM CHIP is 16 MB
i attached picture of motherboard...-
Channel: Troubleshooting & Designing Networks
by EasyGoing1I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
So I decided to implement UPNP...-
- Loading...
