No temporary override function for parental controls on router?
  • japlytic
    • Oct 2005
    • 2086
    Some routers have parental controls, but none seem to have a temporary override function for a particular website (why can't they implement this function?), but they have an "always override" list.
  • mariushm
    • May 2011
    • 3799
    Re: No temporary override function for parental controls on router?
    Probably because they have little memory, it would involve extra processing and because in order to do the "temporary" part they would have to add an accurate time source inside with backup power (if you want the site to be allowed for an hour, the router would have to keep time even if there are power failures and so on)
    I guess you could do it with some custom firmware..
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Netgear has good built in parental controls (powered by OpenDNS) but to bypass it you have to have a certain piece of software installed on the compiter...
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        i need a router to do that it wold need a clock system but a battery?
        Follow the white rabbit.
        • double_DD
          Why does my ISP router hate my "homemade" power supply??
          by double_DD
          It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
          So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
          For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
          07-12-2025, 03:09 AM
          Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
          This is a new item at Electronic GoldMine that has arrived within the last few weeks
          Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
          Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
          https://theelectronicgoldmine.com/products/g28392
          One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
          11-24-2024, 01:25 AM
        • Salvador Pérez
          Help identifying the function of these two coils - MSI Delta 15 (MS-15CK1)
          by Salvador Pérez
          Hello everyone, I'm troubleshooting an MSI Delta 15 (MS-15CK1) motherboard, and I need help identifying the function of the two coils marked in the attached image. The laptop powers on and responds to the keyboard, but the screen does not turn on-neither the LCD nor the backlight. I've checked the main power rails, and all other coils seem to have the expected voltages:
          • 0.91V for the GPU
          • 1.7V for VRAM
          • 3.3V and 5V rails 1.8V for the BIOS
          • 0.9V for the CPU and iGPU 1.2V for the RAM
          However, these two coils are not showing any voltage....
          03-10-2025, 11:50 AM
        • shadow666
          Router Xiaomi M4A Gigabit
          by shadow666
          hello
          i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
          Mi Router 4A Gigabit Edition
          ROM CHIP is 16 MB
          i attached picture of motherboard​...
          11-30-2024, 03:49 PM
        • EasyGoing1
          UPNP, "Standards" and hardware that implements it
          by EasyGoing1
          I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
          One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
          So I decided to implement UPNP...
          07-16-2022, 07:12 PM
