how to get rid of wifi mooches
  • weirdlookinguy
    replied
    Re: how to get rid of wifi mooches
    Where do you buy your wireless cards? I have always considered them dirt cheap, I picked up a few Atheros-based 802.11a/b/g cards at Frys for $14 each several years ago. I still have two in service.
  • kikkoman
    replied
    since when are wifi cards not cheap? usb dongles start from 10$ at Newegg. if you look around, i'm sure you can find better deals.
  • jsog
    replied
    A few old 802.11b cards can be upgraded in firmware to handle WPA, like the Intel 2100. Still 802.11b speed, but it's encrypted.
    There's always wired. It's faster and you don't have to worry about the neighbors plugging in a cable.
  • sofTest
    replied
    If you don't mind a little waiting, DealExtreme got WiFi-cards/-dongles for less than US$ 10 incl. shipping.
  • ratdude747
    replied
    so what do you suggest? yeah. she might not be a noob... but wifi cards aint cheap anmd i really don't want to use WEP.
  • lmcancu
    replied
    Assuming that "prettygirl' is a noob, what Ratdude has done is the simplest way to prevent her from using his AP. Her client won't see the AP since its not advertised, and since he changed the SSID she can no longer connect to it.This assumes, of course, that she is a noob. If she weren't a noob then she would easily find the AP again but we are making that big assumption here ... As for legitimate users, all he has to do is tell them the new SSID.
  • jsog
    replied
    It's hidden. Although some would say that hiding an SSID is just putting a sign on it that says "please ignore me", and since the SSID is broadcast in other ways, it's not very effective and makes things more difficult for legitimate users.
    Call me skeptical, but I'd also guess that "prettygirl" is neither.
  • smason
    replied
    i changed the ssid slightly and turned off broadcast. bye-bye mooch!
    How's that going to help? She'll just connect to the new ssid.
  • ratdude747
    replied
    well then i should be good... the mooches won't see my network.
  • kikkoman
    replied
    as for hackers, that could be true. if someone just wants free wifi though, he/she'll probably go the easiest route.
  • ratdude747
    replied
    it was an mshome workgroup... still, wep sounds like fail... here is my logic:
    say there are two houses. one has no deadbolt (you can kick in the door) and the other has a fancy lock and deadbolt setup that you know is a defective model that can be hacked in 30sec.
    a robber will often hit the second house. why? the second house likely has nicer goods since the owner decided it was worth a lock; something was worth securing.
    in this case, a security-less network (hidden) will outdo wep. hackers will hit the wep networks first since the owner felt inclined to try to secure it and therefore there is likely some files worth exploiting (financial stuff, passwords, etc.). the one without likely has nothing.
  • severach
    replied
    Linux can bust through WEP in a couple of minutes. Windows is still a no show. If prettygirl doesn't run Linux then WEP is more secure than Fort Knox. If she does run Linux then you'd better get to know her.
  • ratdude747
    replied
  • smason
    replied
    Originally posted by digge
    Unless youre using a linux box or similar as AP i dont think so. The normal way most routers work is you put in the allowed mac adresses. Can be a bit of a hastle when you have friends over that wants to use your network.
    Yeah my network is doubly bad. Whenever a friend or relative comes by with a new device, I have to add the MAC to the wireless access point, and add the MAC to my DHCP server (seperate box) . That keeps my network pretty secure, and Arpwatch and Snort tell me if anything new shows up.
  • digge
    replied
    is there a way to specifically ban MAC addresses?
  • ratdude747
    replied
  • jsog
    replied
    From 2005, but still relevant: The six dumbest ways to secure a wireless LAN
  • kikkoman
    replied
    capture some packets from that client and have a look what's inside.
    it shouldn't take you too long to find out who they are.
  • kc8adu
    replied
    secure it,shut off ssid,and set up a junk pc with fakeap with your original ssid.drive em nuts trying to connect.
    they might even think their stuff is broken.
  • smason
    replied
    WEP is "reasonable" security. Yes it can be hacked, but realistically, what are the chances of any of your neighbors being tech-savy enough to do it.
    For your purposes, do MAC address filtering and WEP, and you're "good enough" just monitor it and if you notice a problem, then change.
  • howardc64
    M557-G0 no WiFi/Bt no WIFIVendor file?
    by howardc64
    Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
    • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
    • Service Menu shows many Bt/Wifi info missing
    • Vizio app shows no WIFIVendor file
    Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
    • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
    10-15-2024, 01:12 PM
    HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
    This specification for the HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + Backpack & Wireless Premium Mouse boardview and 640 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
    09-06-2024, 03:30 PM
    HP EliteBook 840 G6 + Backpack & Wireless Premium Mouse Notebook 800 Specification for Upgrade or Repair
    This specification for the HP EliteBook 840 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Backpack & Wireless Premium Mouse boardview and 840 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
    HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Backpack & Wireless Premium Mouse boardview and 430 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
