Ubiquitiu 24 port POE. Help Identify Diode 3pin)
  • gurj1979
    • 186
    Hi again guys.
    Ive got a Ubiquiti 24 port POE Switch which has failed to work. Fans turn on, but no lights.
    I've ripped the board out, flipped it upside down and noticed a blown 3pin SMD Diode (at location D53). Marking is ESSP (as with all the other Diodes in the same row).
    Anyone help me identify the model of this Diode ?
    • 21070
    Re: Ubiquitiu 24 port POE. Help Identify Diode 3pin)
    Originally posted by gurj1979
    Hi again guys.
    Looks like E5SP (five) to me .
    https://cdn.badcaps-static.com/pdfs/...04da442b01.pdf
    • gurj1979
      • 186
      You might be right. Terrible laser engraving by manufacturer. lol
      • gurj1979
        • 186
        I think I found it.
          • 21070
          I just added a picture and the same schematic at the same time as you posted
          • gurj1979
            • 186
            haha snap.
            Thanks for helping.
            • gurj1979
              • 186
              The SoC is dead short to ground for 1v supply.
              Must have been that ESD Diode that did it.
              Ordered a new one (call it a dead one as always) from AliExpress. ETA 12th Sept.
              Broadcom BCM53344A0KFSBLG
              • gurj1979
                • 186
                Chip arrived, put it in, worked for a while. Connected Ground strap and chip died again.
                Found that something called Sidactor was shorted, causing voltage to go from 48v to Ground. Got another new CPU. New Sidactor ordered from RS Components. Will try it all out again tomorrow.
                • gurj1979
                  • 186
                  Update - So all that works fine now Happy days.
                  But I noticed Port 12 only works at 10/100 (Orange LED). All other ports work at 1000 (Green LED).
                  Any ideas ?
                    • 31070
                    if the overvoltage protector failed (sidactor?)
                    then i would check all the transformer windings and the related caps and diodes - compare readings to a working one next to it
                    • gurj1979
                      • 186
                      Looks like Port 12 is linked to LAN Transformer M-TEK G48209SNG.
                      So now I have to out where I can get this or equivalent from in UK. Perhaps RS Components again for quick and cheap price.
                      I'll update when I have some more new. But so far this is looking good.
                        • 31070
                        dont just buy stuff, it could be a bad cap or diode or unfortunatly the chip it all feeds into
                        • gurj1979
                          • 186
                          6 pins (3 each on opposite ends) are giving zero ohms whereas others have high resistance.
                          I will check again for shorted caps but I didn't come across any today. Perhaps use my thermal cam.
                            • 31070
                            that 0 ohms could be the transformer windings,
                            check against the diagram
                            http://en.mag-tek.com.cn/product/264...oductCateId=46
                            • gurj1979
                              • 186
                              Correct for 3 pins in 1 side, but not on the opposite side. It turns into magnetic inside the transformer, then outputs to the opposite end. None of the other transformers are 0 ohms on opposite ends.
                              I'll check again for caps today in a couple of hours.
                              • gurj1979
                                • 186
                                Update.
                                I've removed the The M-TEK Lan Tranaformer and one of the coils is burnt to smithereens.
                                See the pic. 2nd coil from left.
                                Now I can't buy this LAN Transformer anywhere in UK, not most of the world.
                                Can someone help me find a suitable replacement ?
                                It's 48 pins, 10/100/1000 POE, Single Port, 350uH.
                                From the datasheets, the left side has 2 pri coils, and right side has 1 sec coil. But most replacements on the market are Dual Ports with coils on opposite sides.
                                If I buy Dual Ports, would it affect the way the switch works ?
                                Thanks for all your help so far.
                                • gurj1979
                                  • 186
                                  I've ordered this as it's the nearest thing I could find. Although it's Dual Ports instead of Single Port, I can't how it makes any difference. All the pins match up, the coils are in the exact same order as original, only the casing is larger by a couple of mm. Will try it later today.
                                  https://uk.farnell.com/te-connectivi...-ddd7-00001003
                                  • gurj1979
                                    • 186
                                    Result. Works a treat. Port 12 now has Green light 1000mbps. Job is a goodun.
                                    See pics for comparison of the 2 LAN Transformers.
                                      • 31070
                                      nice.
                                      lucky you only needed one, the extra width would envolve cutting the ends off the package.
                                      • gurj1979
                                        • 186
                                        Very true. But I found that port 12 POE doesn't work neither. Works as non-POE. So back to the drawing board. Getting closer though.
                                        • SuperAman
                                          PS5 HDMI port diode reading?
                                          by SuperAman
                                          I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                                          02-03-2024, 10:16 PM
                                        • hobostove
                                          Corsair RM1000e - Help identify 5VSB Zener diode
                                          by hobostove
                                          Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                                          Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                                          There's a 22ohm resistor that's melted and open, but it still has the bands.
                                          The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                                          It looks like the diode connects the source and drain of a TNY284...
                                          03-27-2025, 02:25 PM
                                        • jjne
                                          AUO M270QAN01 - identify diode?
                                          by jjne
                                          I have a small number of monitors based on the above panel and am working through them. I have at least two with a single, burned-out diode. From what I can see it's something like DI428 or DII428 or DH428. Here's a picture of a working one.
                                          Can anyone identify this please? Based on the number 428 it may be a shottky or a Zener according to Google. The device in question is D105.
                                          ETA I can confirm that the number is definitely 428 (I took a video which revealed a better image), the DII appears to be a maker's mark. There's also a code 1G. Looking around...
                                          01-24-2024, 08:39 PM
                                        • jezzaaaa
                                          Identify replacement diode
                                          by jezzaaaa
                                          I'm trying to find a replacement diode for one that has gone short.
                                          I have a generic USB charger that went short circuit to ground on 5V. I found that one of a pair of identical diodes in parallel (and in series with transformer secondary winding) has gone short in both directions, so I suspect it's bad. The marking is CSRS1045, which I believe is a low barrier Schottky with max current 10A and max reverse 45V. I found a spec sheet for CSRS1045-A that has same specs and also says 350mV drop when forward biased.
                                          I can't find the exact part number for sale. Similar...
                                          05-09-2023, 11:26 PM
                                        • fredyjbi
                                          please help, friend, thinkpad L480 NM-B461 rev 1.0 JDOCK1 type C port 5volt only, thank you
                                          by fredyjbi
                                          I have a thinkpad L480 NM-B461 rev 1.0 laptop functioning normally with Type 1 port (JUSBC1)
                                          if you use port type C 2 (JDOCK1) with a usb type meter it only displays 5v, thank you
                                          I tried to look at the schematic diagram USBC_VBUS20, which is the port path from JusBC 1 to U4701 then goes to the system2 charging IC, why is there no system2 path leading to the charging IC on the TYPEC_VBUS20 port which is JDOCK1, thank you for your help.
                                          if you look at the power sequence there must be 2 types of port type C a (JUSBC1) via U4701 and port type C b (JDOCK1)
                                          On the type...
                                          07-09-2024, 11:28 PM
