Acer 1716B no picture, Blinking power light
  • retiredcaps
    • Apr 2010
    • 9271
    #41
    Re: Acer 1716B no picture, Blinking power light
    Personally, I have done something similar and find the new caps will still work fine as long as their is some solder pad left. I just choose really good caps so they last and hope I don't have to resolder anytime soon.
    Others may have different viewpoints, but I think you will be okay if you just leave them.
    I have also actually lifted the entire solder pad and then had to put in jumper wires to get connectivity.
    --- begin sig file ---
    --- end sig file ---
    • nico95
      • Apr 2010
      • 36
      #42
      Thank you, I hope to get the rest of the soldering tonight them, when I get a moment and report back
      I was amazed at how the easy the trace came, off this is only the second monitor I have worked on and the other seemed to have much better traces I'm guessing. I have had problems with traces on really on stuff like the Atari 2600, but was a little shocked on this on. I will reall be more careful now knowing these are that delicate. I another Acer to work on so will see.
      Will I be ok on the Transisstors as well?
      Out of Curiosity, and for future reference. If I had to run a jumper would I just run it to the nearest trace in the same circuit, and in most cases it wouldn't matter what the component is? I have had to run a jumper once I believe but it was for something minor like a battery connection or or for a trace for a wire harness. I wasn't sure if something like a Cap or a Transistor or Voltage regulator would make a difference or a re mroe touchy as long as it a connection. I didn't know if wire size and such would matter much?
      Thanks,
      Nick
      • retiredcaps
        • Apr 2010
        • 9271
        #43
        Yes.
        That is what I did for my Benq power board. I ran it to the nearest trace in the same circuit and nearest component. I used a multimeter to verify the circuitry and that I had continuity.
        • nico95
          • Apr 2010
          • 36
          #44
          Great, that is good to know. I have a feeling I will run into that, I know I have a Atari I have to still jimmy rig bagtogether. I Got a new NOS wire connector but a bunch of traces are really bad, so time permitting I will be doing that.
          Thanks, and I will post how I made out on the monitor,
          Oh one more question if you don't mind. I had to waste a new post. I bought more caps for another monitor(acer 1706) same problem but that had bulging caps. I didn't test the caps or anything else. I I am jsut going to replace the caps and fireher up and see How I make out. Since the caps are bulging I thought that would be the way to go and not wate time testing other stuff, will that be ok, That is replacing the caps and if there was another problem Im guessing I won't cause any more harm buy doing so?
          • retiredcaps
            • Apr 2010
            • 9271
            #45
            I didn't test the caps or anything else. I am jsut going to replace the caps and fireher up and see How I make out.
            I love to use my multimeter so I will typically test everything before I power up and put the covers back on.
            If I'm lucky enough nowadays to get a lcd monitor, I don't know the history so I will test the bridge rectifier, fuses, power mosfet, inverter transformer with ohms to see if they are okay. After I replace the caps, I will check DC voltage to make sure they are stable.
            In addition, I will measure the uF of the new caps and bad caps.
            All the above probably takes less than 10 minutes.
            • nico95
              • Apr 2010
              • 36
              #46
              Sound like I need to make a new post maybe, I'm still learning at that other testing. I learning some from this monitor last time you helped me with the transistors. I guess I can get this one going and then start an new post on the other, maybe you could direct me on the testing of those parts in the other possiblely ?
              • retiredcaps
                • Apr 2010
                • 9271
                #47
                A lot of this is already documented starting with post 13 and 14 at
                https://www.badcaps.net/forum/showthread.php?t=10419
                • PNI E.
                  tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                  by PNI E.
                  hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                  02-20-2025, 08:36 AM
                  09-06-2024, 05:27 AM
                • paulyboy
                  Acer Spin 5 LC56-14A AMD White Light on Esc and Caps lock Key and Blinking power btn
                  by paulyboy
                  System doesnt post, I have found that 3v 5v and 19v rails present and accounted for.
                  theres 19.5v with a 2amp current drawover usb c charging
                  I have tried a new bios and cleaned me region but no change in behaviour.
                  I have noticed that the Mosfet PU4403 gets quite hot 60 degrees, but cannot find a short on it or surround components also pu4401 which is the BQ charging chip is also quite hot 60 degrees.
                  Have removed BQ and checked pads but no shorts.
                  Also on PU4405 PIN 2-4 is suppose to be 19v as per schematic 19V_dcbatout...
                  09-12-2023, 05:32 PM
                  Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                  This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                  09-07-2024, 05:00 AM
                  Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                  This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
