Re: Acer AL1916W
A bad bridge rectifier means no power at all.
If the backlights are not turning on at all (not even a flash), it may mean you have an open fuse or shorted transistor somewhere on the inverter board/section.
Start by posting clear focused pictures (top down view - both sides) after reading
https://www.badcaps.net/forum/showthread.php?t=1868
Acer AL1916W
Re: Acer AL1916W
I guess I am just jumping to quick conclusions, and should probably test more. The LCD is working, just the lights arent turning on - does that mean the bridge rectifier is working properly?Leave a comment:
Re: Acer AL1916W
OK, I will work on that tonight. Any suggestion on which one / where to order a new rectifier from?Leave a comment:
Re: Acer AL1916W
If it is above 100 ohms, the bridge rectifier is probably good.Leave a comment:
Re: Acer AL1916W
Hey guys- I've been searching for this info all day and glad I found this place! I started to test my rectifier and noticed my numbers were all over the place.
Does anyone have the specific range that all the contacts need to have between the others?Leave a comment:
Re: Acer AL1916W
Diodes are supposed to allow current to flow only in one direction so that is why you need to test the in both directions. One side should read 0.5 to 0.7 and the other reading should be 0L.
This definitely sounds like a shorted bridge rectifier.Leave a comment:
Re: Acer AL1916W
with the multimeter set to 200 ohm:
black on 1, red on 2 - 1
black on 1, red on 3 - 1
black on 1, red on 4 - 1
black on 2, red on 3 - 1
black on 2, red on 4 - .4
black on 3, red on 4 - 1
red on 1, black on 2 - 1
red on 1, black on 3 - 1
red on 1, black on 4 - 1
red on 2, black on 3 - 1
red on 2, black on 4 - .4
red on 3, black on 4 - 1
I will remove the rectifier tonight and retest.
ThanksLeave a comment:
Re: Acer AL1916W
with the multimeter set to 200k ohm:
black on 1, red on 2 - infinity
black on 1, red on 4 - infinity
black on 2, red on 4 - 0
diode test:
black on 2, red on 3 - .512
red on 1, black on 2 - .477
red on 1, black on 3 - .517
red on 1, black on 4 - .476
red on 2, black on 4 - 0
red on 3, black on 4 - .511
please tell me I did this right.
If pin 2 and 4 on the 200ohm test still shows a low reading (like < 2 ohms), you have a probably shorted bridge rectifier. To verify, remove it from the board and retest out of circuit just to be sure. If it is bad, you will need the model number and replace it.Last edited by retiredcaps; 07-30-2010, 03:09 PM.Leave a comment:
Re: Acer AL1916W
With power off and unplugged.
1) set your multimeter on ohm
2) number the rectifier pins 1 to 4
3) put black on 1, red on 2 - record ohm
4) put black on 1, red on 3 - record ohm
5) put black on 1, red on 4 - record ohm
6) put black on 2, red on 3 - record ohm
7) put black on 2, red on 4 - record ohm
8) put black on 3, red on 4 - record ohm
You should have 6 ohm readings.
Do same test as above, but with diode setting AND you want to reverse black and red.
You should have 12 diode readings.
red on 1, black on 2 - infinity
red on 1, black on 4 - infinity
diode test:
please tell me I did this right.Leave a comment:
Re: Acer AL1916W
Quick question ,Have we ever determined if the fuse is good?
Al.Leave a comment:
Re: Acer AL1916W
Originally posted by zwahelianJust to clarify, I should check the rectifier with it desoldered from the circuit board?Leave a comment:
Re: Acer AL1916W
Re: Acer AL1916W
Originally posted by BullParWhat kind of meter are you using? Dont use the tone setting that can give you false readings.
A good fuse should read 0.3 ohm.
Post a picture of your multimeter.
Before you order anything, you should check the bridge rectifier. That may be shorted.Leave a comment:
Re: Acer AL1916W
What kind of meter are you using? Dont use the tone setting that can give you false readings.Leave a comment:
Re: Acer AL1916W
Please bare with me... I am a total noob when it comes to this stuff. The multimeter I'm using has many different settings, and I found the resistance tone setting which should give me a tone when touching the leads of the 2A/250V fuse, right? I think I was using it incorrectly and misread that the fuse was fine. I get no tone at all when touching the ends of the fuse. Should I go ahead and order a replacement from digikey?
Also, could someone recommend the most appropriate fuse on Digikey's site?
Will part # F3292-ND or F3297-ND do the trick?
Thanks again, gaining the experience is invaluable.Leave a comment:
Re: Acer AL1916W
Originally posted by zwahelianThe fuse is fine, how do I test the rectifier to see if it is shorted?
You should have 12 diode readings.Leave a comment:
Re: Acer AL1916W
The fuse is fine, how do I test the rectifier to see if it is shorted?Leave a comment:
Re: Acer AL1916W
Originally posted by zwahelianThe power LED light doesn't light up at all. I swapped PSU's with the good monitor and it works fine, so at least I've narrowed it down to the PSU. The only capacitor I didn't replace was the big 100uF 450v su'scon. When the PSU is plugged in, I get no voltage from the leads of the large cap with my volt meter.
1) test fuse to see if it is open
2) test rectifier to see if it shorted (it is the black long rectangular thing and should be marked with a D on the PCB)Leave a comment:
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by maralexbarI ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
If anyone knows how to force the external monitor as primary for Notebooks of those models11-02-2024, 09:18 AM -
by noah95Hello everyone, i have an old acer monitor "AL 1916W"
it was totally dead but after i replace some bad caps now the led turns green and red when it's in sleep mode.
but the picture at all no backlight or a dim picture in the LCD.
i just wanted to know how can i test the backlight and the lcd or from where to measure the voltage going to the backlight or the lcd, to know if the problem in the psu or not.
i did test most of the component there if there's a short but they seems fine.
by bripollHello, I have an Acer veriton n4670GT that, due to a fall to the ground, only started if I did a BIOS reset.
The power button ar ok, and when power off windows, then if press power button, this power on, but goes to boot loop, like press power button forever
It crossed my mind to try a BIOS update and when I finished it turned off and no longer starts in any way.
I have a flash programmer, but the file you download from the Acer website has a .CAP extension, it is not a .BIN
I have programmed it, but it still won't start, it is dead
Before programming...-
11-23-2023, 02:56 PM -
This specification for the Acer Aspire Aspire 9920 G-933G64HN can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire 9920 G-933G64HN boardview and Aspire 9920 G-933G64HN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 05:27 AM
- Loading...
