Acer AL1916W
  • retiredcaps
    • Apr 2010
    • 9271
    #41
    Re: Acer AL1916W
    Also, what are the part numbers of
    IC201 and IC202 (top side)
    U101 and probably U102 (the other legged IC on the bottom side)
    edit: And measure the resistance of the inverter transformer pins S1 to S2 and S3 to S4 (in circuit - power OFF and LCD unplugged) as per
    http://lcdparts.net/TransformerDetai...ProductID=3360
    Both should read around 650 ohms.
    --- begin sig file ---
    --- end sig file ---
    • alexanna
      • Mar 2010
      • 1346
      #42
      Re: Acer AL1916W
      Originally posted by mscott03
      The dark green caps are Taicon.
      I just finished replacing all the bad caps since I got the new ones today and still no power to the lights. LCD works, image shows up, green power light comes on, just no juice to the lights..
      on the back side of the board,Is f200 good?
      Al.
      • mscott03
        • Aug 2010
        • 16
        #43
        Re: Acer AL1916W
        IC201 and 202 have this p/n:
        P605
        BZ6G1S
        U101 and 102 have this p/n:
        B U3
        PC817
        As for measuring resistance of the S1 - S2, and S3 - S4.. How do I know which contacts those are? Mine are not labeled, not sure if they normally are.
        F200 looks fine, but I am not sure what a bad one looks like, doesnt seem to have any damamge to it though.
        • mscott03
          • Aug 2010
          • 16
          #44
          Re: Acer AL1916W
          Edit: Replied too soon before visiting the site! I see which contacts those are -
          • retiredcaps
            • Apr 2010
            • 9271
            #45
            Re: Acer AL1916W
            S1 - S4 are the outside pins of the transformers.
            To measure a fuse, put your multimeter on ohms (probably 200 ohms). Put black on one side, red on the other side of F200.
            A good fuse should read 0.3 ohms. If it reads "1" or 0L, it is an open fuse (blown).
            edit: BTW, that is a good catch on finding F200. I never expected to see a fuse on the bottom side on a board. Normally they are on the front side.
            • mscott03
              • Aug 2010
              • 16
              #46
              Re: Acer AL1916W
              Meter reads .764k ohm on first and .761k ohm on second....
              • retiredcaps
                • Apr 2010
                • 9271
                #47
                Re: Acer AL1916W
                Are you talking about the transformer? If yes, the transformer is likely good. This test doesn't catch a shorted turn on the transformer, but let's assume it is good for now.
                • alexanna
                  • Mar 2010
                  • 1346
                  #48
                  Re: Acer AL1916W
                  There was a explanation given for manufactures using the small surface mount fuses. To keep the everyday user from thinking if 2a is good then 4a must be better, I think it was plainBill.
                  A lot of the delta boards use them .F200 is important to check because it supplies power to the back light controller.
                  Al.
                  Last edited by alexanna; 09-01-2010, 03:58 PM. Reason: i cat figure out how to quotew
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #49
                    Re: Acer AL1916W
                    Al.
                    Still a great catch on spotting F200. I would have looked on the front side PCB forever.
                    Also for all the newbies and first time posters, this is a good example why clear focused pictures are required. If this were some fuzzy, out of focus, 800x600 pic, we (Al) would have never spotted this fuse.
                    • mscott03
                      • Aug 2010
                      • 16
                      #50
                      Re: Acer AL1916W
                      You guys are awesome! When I test the F200 fuse should I have it off the board, or will it test properly still soldered on?
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #51
                        Re: Acer AL1916W
                        In circuit is fine.
                        edit: report actual ohm reading
                        Last edited by retiredcaps; 09-01-2010, 07:52 PM. Reason: edit: report actual ohm reading
                        • mscott03
                          • Aug 2010
                          • 16
                          #52
                          Re: Acer AL1916W
                          When I test one direction I get 0L, and the other way continuously climbs from 2.4k Ohm up. Blown fuse? I will replace it tomorrow morning after checking back later with you all.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #53
                            Re: Acer AL1916W
                            Yes, blown. It should read 0.3 ohms. If that is the root cause, you can give a big thanks to alexanna. There is no way, I would have seen that fuse. I will remember to look for that in the future though.
                            • mscott03
                              • Aug 2010
                              • 16
                              #54
                              Re: Acer AL1916W
                              I replaced the fuse and noticed something in the right direction, now when it powers up the lights flash or flicker for a second then shut off..
                              • jetadm123
                                • 2169
                                #55
                                Re: Acer AL1916W
                                You might want to check IC201 and IC202 for shorts. Apparently, this board is prone to one of those chips failing. Replace them in pairs. Part number is AOP605 and available from digikey for under $1.00 each.
                                • alexanna
                                  • Mar 2010
                                  • 1346
                                  #56
                                  Re: Acer AL1916W
                                  Dose the fuse remain good,After the flash?
                                  Al
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #57
                                    Re: Acer AL1916W
                                    Agreed.
                                    You can test for shorted transistors "in circuit" (with power off and unplugged)
                                    a) put black probe (com) on pin 1 and red probe on pin 2 - read ohm
                                    b) put black probe (com) on pin 1 and red probe on pin 3 - read ohm
                                    c) put black probe (com) on pin 2 and red probe on pin 3 - read ohm
                                    If any ohm reading is less than 40 ohm you probably have a shorted transistor and it will need to be replaced. Test it out of circuit to verify.
                                    • alexanna
                                      • Mar 2010
                                      • 1346
                                      #58
                                      Re: Acer AL1916W
                                      Agreed.
                                      the aop605 is in a dip -8 package I have not looked at data sheet but testing is going to be different.
                                      Al.
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #59
                                        Re: Acer AL1916W
                                        Al.
                                        Too much sun today.
                                        You are correct. I'm getting my threads all mixed up (have 7 tabs open right now). Ignore my previous instructions.
                                        edits below:
                                        Datasheet at
                                        Test S1-G1, S1-D1, G1-D1. Note there are 2 D1s.
                                        Test S2-G2, S2-D2, G2-D2. Note there are 2 D2s.
                                        If my math is right at 12:30am, that should be 12 readings.
                                        • alexanna
                                          • Mar 2010
                                          • 1346
                                          #60
                                          Re: Acer AL1916W
                                          I knew i would wake you back up. have a good morning.
                                          Al.
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • maralexbar
                                            How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
                                            by maralexbar
                                            I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
                                            It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
                                            If anyone knows how to force the external monitor as primary for Notebooks of those models
                                            11-02-2024, 09:18 AM
                                          • noah95
                                            Dead Acer AL 1916W Monitor
                                            by noah95
                                            Hello everyone, i have an old acer monitor "AL 1916W"
                                            it was totally dead but after i replace some bad caps now the led turns green and red when it's in sleep mode.
                                            but the picture at all no backlight or a dim picture in the LCD.
                                            i just wanted to know how can i test the backlight and the lcd or from where to measure the voltage going to the backlight or the lcd, to know if the problem in the psu or not.
                                            i did test most of the component there if there's a short but they seems fine.
                                            03-25-2022, 03:12 AM
                                          • bripoll
                                            Acer Veriton N4670GT Dead
                                            by bripoll
                                            Hello, I have an Acer veriton n4670GT that, due to a fall to the ground, only started if I did a BIOS reset.
                                            The power button ar ok, and when power off windows, then if press power button, this power on, but goes to boot loop, like press power button forever
                                            It crossed my mind to try a BIOS update and when I finished it turned off and no longer starts in any way.
                                            I have a flash programmer, but the file you download from the Acer website has a .CAP extension, it is not a .BIN
                                            I have programmed it, but it still won't start, it is dead
                                            Before programming...
                                            11-23-2023, 02:56 PM
                                            09-06-2024, 05:27 AM
