A guide on how to troubleshoot 2 seconds to black
This is a sticky topic.
  • stevwills
    • May 2016
    • canada
    #61
    Re: A guide on how to troubleshoot 2 seconds to black
    Originally posted by stevwills
    the both lamps don't turn completely on. they kinda turn on like a loading screen. (they both go at the same pace.) and before they hit the end, the monitor turns off.
    when is say the monitor turns off, i mean only the panel. the speakers and the power led stayes on.
    • mikail13
      • Aug 2013
      • 93
      • Turkiye
      #62
      SAMSUNG P2270HD
      2 Second to black
      other parts are O.K. ie. CCFL.
      this power board kills my life...
      everthings seems O.K.
      i.e. caps. i test them on board.
      any idea?
        You should make a thread regarding to your monitor, this thread is for the guide only, not for any particular model.
        • mikail13
          • Aug 2013
          • 93
          • Turkiye
          #64
          i get it. it can delete. how can i move the post and pics?
          i re-upload pics on new thread..
          please delete my last two post on there..
          • ronie1981
            • Sep 2019
            • philippines
            #65
            Very useful thread, thank you for sharing...
            • kadi144
              • Aug 2015
              • 690
              • algerie
              #66
              thanks for sharing.
              • dnytwaryors
                • Aug 2023
                • 54
                • Philippines
                #67
                Thank for this information
                • Rick_1234
                  by Rick_1234
                  Good evening, gentlemen.
                  Things I tried
                  06-22-2024, 04:44 PM
                • sew333
                  Pc shutdown, monitor flickered with no signal after 10 seconds
                  by sew333
                  My pc:
                  10850K stock 4800mhz stock Kraken X73 good temps
                  2x16 GB DDR4 GSKILL 3000mhz XMP
                  Seasonic Tx-850 Ultra Titanium
                  Gigabyte Rtx 3090 Gaming OC
                  Aorus Z490 Pro Gaming
                  1 TB SSD
                  4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                  Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                  Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                  Power...
                  02-22-2022, 10:27 AM
                  by momaka
                  03-15-2023, 10:17 PM
                • DanPoka
                  by DanPoka
                  02-15-2025, 05:05 AM
                • ttmi100x
                  HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                  by ttmi100x
                  Greetings everyone,
                  I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                  The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                  Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                  Upon closer inspection...
                  07-31-2024, 06:36 PM
