Ballast for low pressure mercury lamp
+ More Options
Posts
  • nascheme
    • Nov 2009
    Sorry for the offtopic post but I hope someone here has some advice. My parents live on a farm and use a UV sterilizer for their water. The ballast on the low pressure mecury UV lamp keeps blowing caps and fuses. I'm wondering if it's due to bad power, bad components or just bad design.
    A little searching reveals the following patent: US 6274988 (. The circuits in the patent appear to match the board I have. The half-bridge driver is a International Rectifier IR2151. The two MOSETs are IRF830. The big electrolytic caps (47 uF, C1 & C2 on page 3 of the patent) don't seem to have a name, CE EB (stylized 3 or M), 105 degC, 250 V. The board has the year 2002 on it.
    The board around the MOSETs is darker, I suppose due to overheating. Is this thing worth trying to repair? How would I go about verifying the operation of the circuit? I have a 10 MHz DS oscilloscope.
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Ballast for low pressure mercury lamp
    that would be Panasonic a.k.a. Matsushita
    • nascheme
      • Nov 2009
      Originally posted by Scenic
      [...] Panasonic a.k.a. Matsushita
      Yup, that's it. Thanks.
      • Toasty
        • Jul 2007
        • 4171
        If it's blowing C1 & C2 & fuses, then I would say that at least one of the rectifiers D1,2,3,4 is bad (shorted). That would allow AC from the mains into the caps and take them and the fuse out.
        Check also C4 for shorting and R1 for value.
        Toast
        veritas odium parit
        • nascheme
          • Nov 2009
          Good call, thanks for your help. All four of the bridge diodes have 0 Ohms of resistance both ways. I have another ballast that blew a fuse but the diodes appear to be okay on that one.
          I couldn't find these after searching for a while. I guess the circuit in the patent is not exactly the same.
          A few more things I found:
          • The circuit appears to be some type of flyback converter. The circuit seems very simple compared to other real world switchers.
          • There is no in-rush limiting for the two 47 uF caps connected to the recifier. Based on Horowitz & Hill, I understand normally there would be some protection (e.g. a thermistor).
          • As far as I can see, there is not much for protection circuity (e.g. over voltage crowbar, etc).
          • There is a variable resistor that is supposed to tune the circuit. I'm wondering if I replace the caps and diodes, if I have to re-tune it.
          If it's useful, here is a picture of the board:
          The black and white wires at the top are line power. The four wires below go to the low pressure mercury bulb. I'm wondering now if I should:
          • Fix this thing by replacing components.
          • Replace some components and also make some improvements (no sure what those would be).
          • Buy a new ballast from the same company (hopefully the new one is more reliable).
          • Trash the whole system and buy a new UV sanitizer.
          Again, sorry for the offtopic post. I was thinking that this circuit would be similar to what drives the lamp on some displays. BTW, I'm guessing it would not be wise to start poking around with my oscilloscope. It's rated for 300 V, I think and this thing probably produces more than that.
          • crtfool
            • Jun 2010
            • 82
            The circuit board and transformer look very toasted - your best option would be to buy a new ballast, in my opinion.
            • Toasty
              • Jul 2007
              • 4171
              Replace the diodes and the caps. You need to test the 2 MOSFETs also. If they shorted, that would overload the rectifiers D1-4, which when shorted could allow AC into the caps blowing them. It's a cascade failure and who knows when the fuse finally made up its mind to open.
              I am also concerned about the small ceramic cap just below and right of the transformer. The top looks cracked. If so, that needs to be replaced also.
              If the ballast transformer is shorted, then it's time for a new unit. The newer units seemed to have been revised as 1 unit for all voltages. Previously there were 2 - One for 120v and another for 240v.
              R1 is probably one of the 3 large resistors. A backside shot of the board would make it simple to determine. Since none of the 3 large resistors appear burnt, cooked, or overloaded, at this time I don't believe that the control circuit has failed. R1 is inline and serves as a voltage dropping resistor and current limiter to the chip.
              If you need the diodes, e-caps, ceramic cap, and MOSFETs, it should run less than $20 incl s/h. I think I saw a price yesterday for the whole unit of about $75.
              Toast
              veritas odium parit
              • Toasty
                • Jul 2007
                • 4171
                Uploaded pic to forums so it is not lost to future users.
                veritas odium parit
                  Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                  This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                  09-07-2024, 12:10 AM
                • vestaviascott
                  Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                  by vestaviascott
                  Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                  Here's what happens:
                  1) Power on
                  2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                  3) Blue status light flashes for appx 4 minutes...
                  07-29-2020, 06:08 AM
                • mikey5791
                  Help on Samsung Syncmaster T220 dead ccfl lamp
                  by mikey5791
                  This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                  Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                  10-18-2020, 03:17 AM
                • khelane
                  test active pfc power with lamp test
                  by khelane
                  Hello
                  I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                  Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                  Is there a way...
                  06-03-2025, 01:00 AM
                • Yanleb
                  Sharp LC-60LE810UN Lamp Error
                  by Yanleb
                  I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
                  I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
                  Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
                  I've tried all the key...
                  08-24-2021, 11:48 PM
