Samsung SyncMaster 204b
  • PlainBill
    • Feb 2009
    • 7034
    Re: Samsung SyncMaster 204b
    Originally posted by john98103
    IC 304 with tab at top:
    tab = 1.81V
    left pin = 0V
    stub = 1.81V
    right pin = 3.23V
    That's correct for a 1.8 volt LDO regulator.
    The symptoms indicate the processor is shutting down. The power supplies appear to be good. The two possibilities are that a power regulator is shutting down, or a processor is sensing problems. I've been able to identify major parts of the circuit.
    The area circled in red in the upper left corner is the main regulator. It is a type known as a bucking regulator, this puts a high stress on the caps. One option would be to replace the three caps (2 ea 100uF 25V, 1 ea 100uF, 16V) inside the circle. I don't have high hopes for that.
    The area circled in green is the switch for the LCD panel itself. There is no reason to believe that is causing any problem.
    There are two areas circled in umber, one on the left side, one on the far right. By the voltages, these are LDO regulators, and are very unlikely to be responsible.
    The area on the left circled in yellow represents a mystery. It is clearly a bucking regulator, but there is no identifiable regulator. I suspect it is the 8 pin IC, but the part number is not identifiable. Again, you could try replacing the caps, but I can't offer much hope that would help.
    On the right I have circled some pads in gold. That is the area I would expect to find the cable going to the front panel. Which presents a minor mystery - where is the cable to the front panel?
    The chip circled in black is the prime suspect. It is the control processor, and because of the white label, is loaded with a custom program for this monitor. And if it can be positively identified as bad, it is pure 'unobtanium'.
    PlainBill
    • john98103
      • May 2011
      • 20
      A quick update: first of all THANKS for all the effort in helping try to pinpoint the problem.
      I located another identical monitor which had a bad power supply and swaped signal cards; my monitor works fine now. I was going to log all the correct voltages throughout the good board and then compare with the non-working board but my desire to use the working monitor overrode my curiosity and I failed to follow through.
      • kking85743
        • Jul 2011
        #43
        For those who have replaced all the capacitors, but still have trouble with the back light (like me), look for a green resistor-like thing with a f### along side it. These are wire fuses, sometimes called pickle fuses (because they are green?). Unsolder one end and test for continuity. Mine was blown, and a quick trip to an electronics supply store fixed me up. Mine was a 3A unit, yours may be a different value (it was printed on the fuse). Hope that helps!
        • PlainBill
          • Feb 2009
          • 7034
          Not 'pickle fuse', 'Pico fuse'. The name chosen by the manufacturer.
          Other than that, your suggestion is sound.
          PlainBill
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • Chrissygizmo
            samsung galaxy ao2s very temperamental after screen replaced
            by Chrissygizmo
            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
            Ive eventually managed to get it on and working but it's very temperamental...
            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
            05-26-2024, 12:05 AM
          • JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
            by JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
            Please help. Thanks in advance!
            08-12-2025, 11:45 AM
          • Kiberge
            Samsung LH82QENELGC/EN Help needed - Static line on screen
            by Kiberge
            HI guys!
            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
            04-22-2024, 11:28 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
