AOC LM726 made squeaking noise?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5038
    • New Zealand
    This is the same monitor as per this thread: https://www.badcaps.net/forum/showthread.php?t=7414
    I had replaced the capacitors previously and so far it has been working fine.
    But tonight I sat down at my computer and heard a weird noise like something squeaking, which appeared to come from the direction of the monitor.
    It was not continuous, and happened in bursts of random length. During this there was no flickering backlight or picture loss or anything.
    I hit the power button but the noise continued. Then I pulled the plug, and the noise was no more.
    So I think it was the monitor somehow, but I have no idea what could make this noise.
    At the moment it seems to be working fine now, although there does seem to be random popping\clicking noises (not very loud)
    However that may just be the something expanding while warming up again, it's a very cold night...
    Any ideas\thoughts?
    -David VanHorn
  • Agent24
    I see dead caps
    • Oct 2007
    • 5038
    • New Zealand
    Re: AOC LM726 made squeaking noise?
    OK I'm pretty sure the random clicking noises are the plastic case expanding as the CCFLs heat up.
    Still no idea about the weird noise, though. Haven't heard anything yet...
    -David VanHorn
    • tony359
      by tony359
      11-28-2023, 05:18 AM
    • MegaZAC
      Onkyo TX-SR805 noise in one channel
      by MegaZAC
      Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
      Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
      There's some logic behind it. As soon as I select an input I get only left...
      04-23-2025, 10:09 PM
    • karatzdi
      Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
      by karatzdi
      I know some might say... just buy another one. Sell it as parts..!
      So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
      Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
      Spent some time downloading the Service...
      06-11-2024, 08:38 AM
    • EvazX
      ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
      by EvazX
      I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
      Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
      For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
      However, after some time, the replacement motherboard...
      08-25-2025, 06:09 PM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
