Dell E177FPv dropping voltages
  • johnboy183
    • May 2008
    • 119
    I have inherited two identical models of this monitor and can find very little mention of it anywhere and none in Badcaps forum. Both are completely dead as in no power light at all and no startup, flashes or image visible with torch. I have done the usual checks and fully recapped the boards, changed the C5707s and resoldered the transformers, checked the schottkys etc. Still dead. however I have found that the 5v voltage to the logic card pin is there and then over a couple of mins progressively drops to 0.2v. Also at the "hot" end of the board I can measure 15v at startup and this also drops slowly and progressively to almost zero after a couple of mins. This happens whether the board is tested on its own or with the backlights and logic board plugged in. Is this a normal switch off type function and I am chasing the wrong symptom (both boards do exactly the same) or is a faulty component leading to voltage drop?
    Any thoughts most welcome while I still have hair left!
    I am attempting to attach a library photo of the board as my camera is out of use at the moment in case someone recognises the board and the symptoms.
    Johnboy183
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell E177FPv dropping voltages
    Do you get about 160V DC across the main cap? Careful measuring this voltage!
    Did you recap the small caps as well? They are usually 1uF 50V or 2.2uF 50V? On other boards there is also a small cap that is usually 22uF or 47uF/50V.
    Is there a picofuse on the board? (your diagram is too small to see)? Picofuse is written as PF on the board. Example PF801. Test the picofuse for continuity.
    --- begin sig file ---
    --- end sig file ---
    • PlainBill
      • Feb 2009
      • 7034
      Any major troubleshooting assistance will require bigger (and clear!) pictures of both top and bottom of the board, as well as a shot of the logic board.
      The power supply would not have any shut-off function. Retiredcaps suggestion of monitoring the voltage across the large cap is good. Also, look for bad solder joints. That's about the only explanation I can see for the behavior you describe.
      PlainBill
      • retiredcaps
        • Apr 2010
        • 9271
        Also, what brand of caps did you use to recap?
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Depends on what the old ones are rated for.
          So what are they?
          Mann-Made Global Warming.
          - Dr Seuss
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • jasonbay13
            Dell Inspiron 15-3521 ~ LA-9104P ~ No Power - corroded board with pics of damage and some voltages
            by jasonbay13
            it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
            PU200
            pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
            pin 8 vreg3 = 0v
            pin 13 en = .2v
            pin 1,6 entrip1,2 = 0v
            b+ and b++ = 19.5v
            +5valw = 0v & 25+ohm to ground
            +3valwp = 0v & 25+ohm to ground
            i cleaned the board up just a little and can get more pics.​
            where should i be looking? thx...
            09-25-2025, 10:54 PM
          • master3112
            by master3112
            07-29-2025, 01:55 PM
          • Garret Matt.
            DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
            by Garret Matt.
            I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
            Thank you in advance for any assistance you can render.
            Inductor In question. Buzzes like...
            06-20-2025, 01:21 PM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
