Maxdata 101910 same as Viewsonic
  • jeb007
    • Jun 2010
    • 3
    Hello.. I am sorry if I posted this in the wrong place as my previous message ended up at the bottom of a thread,,,
    I hope someone can clarify thias fault.. I folllowed the info from SCENIC . I got a 12V power supply with at least 1.5A handy? (2.5+A would be better)
    if so, you could "inject" it to the pinheader connecting the powersupply/inverter board to the logic board.
    or just solder 2 wires with the right polarity to the cap right next to the pin header.
    that way you can determine if the logic board is OK or not and make sure it's not the power/inverterboard's fault.
    if it still randomly goes into standby mode, it's most likely the logicboard.<<
    In my situation it did make the screen light up but then went blank again.( loops every 6 seconds ) Does this mean it is a fault somewhere on the Logic board or is it on the Invertor board. I have disconnected the primary components of the PSU The Power part of the board also has a problem which I can sort later
    All the CAPs look good from the top but I have not removed any yet. Any guidence from experance wouold be appreciate before I remove all the caps and still find it will not work,, Thanks John
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Maxdata 101910 same as Viewsonic
    could be the inverter's fault or just the PSU being too weak.
    i'm running mine on a 3.75A brick. Tried it with a 2.5A once and it got baking hot, even though the brightness was set very low..
    • jeb007
      • Jun 2010
      • 3
      Hello,, Thanks for your reply The PSU pack I am using is 12V 2.0a so as you say maybe it is not strong enough,........ I have just tried a 12v 6a PSU and the screen does not even flash now.. I monitored the current and the meter blips @.75a for a split second....The green light stays on, Now I am even more confused. John
      • robert
        • Jan 2008
        • 69
        Checked the 3.3V (switching) regulator on the logic board?
        Its among all these green Teapo caps, output had a 6.3v/1000uF Rubycon on most of the units i repaired, but some had a Teapo there which was faulty.
        Also, try manually pulling the ON/OFF line to the inverter high (to 3.3V), the light should be on then. If not, check the inverter.
        If it still doesnt work, the logic board probably is toast, once you ruled out bad contacts or shorts as source of the problem.
        Just recently thrown out a 19" Hannstar (with perfectly good PSU/Inverter, which i kept as spares) because of a faulty logic board (displays stripes instead of video). Its not a very uncommon fault, usually caused by overvoltage or totally toasted power supply caps.
        • Rictech
          Panasonic SA-MAX770PU SMPSU board fault....
          by Rictech
          Hello everyone. 😀
          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
          There are no devices that have exploded or otherwise show signs...
          08-26-2024, 01:05 AM
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
          ESR meter came to the rescue again today with a PLC I/O card fault
          by sam_sam_sam
          I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
          I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
          One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
          12-18-2023, 08:17 PM
        • lostone
          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
          by lostone
          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
          05-19-2024, 11:40 AM
        • cazi1001
          Strange fault on Lenovo ThinkPad E14 Gen. 2
          by cazi1001
          I have a strange fault with a Lenovo ThinkPad E14 G2 (Board No. NM-D011 Rev. 1.0).
          The first Problem, which I fixed already, was a dead TPS65944AD (USB Type-C) controller. After I fixed this fault, all functions working fine and the notebook run very well with the charger and battery.
          On the next day, I tied to start the notebook with the battery, but nothing happened. I started with the charger and on windows, I saw, that the battery was empty. And this was nearly impossible, because the battery was charged. I disconnected the battery and found out, that the board...
          03-24-2024, 04:16 AM
