Proview pl926wbi on for 2 sec and LCD turns off
  • paziu
    • Jun 2010
    Hello, I got this monitor hoping for an easy fix, well, it is not that easy ( for me ... ) - beside the fact that this is a very >cheap< made device, and its guts look like after a cat5 hurricane, I managed to replace 2 bad caps on the power supply and the inverter... there was a cold solder joint also on a 220uF..
    it has 2 circuits x 2 CCFLs outputs ( for top and bottom ) - tested the outputs with a spare CCFL set i got, both TOP outputs are good, both BOTTOM are DIM ( 25% lit ) - the LCD have all 4 CCFLs good. The top and bottom circuit powers off with either 4, 2 or no CCFLs connected, the voltages on the power supply, and going to the VGA board look good and stable. there is two transformers, for top and bottom, two coils - black squares, and nothing that looks suspicious the voltages are same on both circuits ( difficult to measure since it cuts off quickly, after 2 sec of "good" display - and no, it does not go into suspend ) I am basically running out of ideas...
    Thank you for any suggestions!
    paziulek
  • FIXITNOW
    • Jun 2008
    • 128
    Re: Proview pl926wbi on for 2 sec and LCD turns off
    last one ihad i replaced 4 x 470uf Capcitors dead and 1 220uf Capcitor dead
    if no better check the ams1117 regulator. is outputting a 3.3v.
    • PlainBill
      • Feb 2009
      • 7034
      paziulek
      Bad transformer in the inverter (82% probablility).
      PlainBill
      • paziu
        • Jun 2010
        Thank you very much for the reply,
        I will check the regulator - if there is 2, one for top CCFLs and another for the bottom, than this could be the reason... From what I see, there is 2 independent transformers, and I also will check for the part# availability, as soon as I have any results I will let you know, thanks again!
        • paziu
          • Jun 2010
          before doing anything that involves spending a few dollars, and waiting another week, I decided to swap the transformers on the board - PlainBill - the 82% probability became 100% fact, one of the transformers is shot, now the top CCFLs are dim - bottom became bright... THANKS!
          now I need to find a decent price, $20 for the part is still too high... I could get an another wide screen "patient" for this price.
          What I also tried, is removing the bad transformer and connecting the CCFLs to just the GOOD circuit - the picture is quite bright, but it still cuts off after 2 sec.. so I am guessing the circuit cuts off if there is too much or too little current... I do not know, just a guess.. for sure it is not within the "norm" - is it possible I got an another bad part there or is it known, that the protection will disconnect the circuit if "one of two transformers is missing" ?
          Thank you again! I will hunt now for the transformer or an another BAD Proview...
          paziu
          • Stephen
            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
            by Stephen
            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
            03-15-2024, 09:37 AM
          • andrhouseolly
            Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
            by andrhouseolly
            Hi.
            I kindly ask you to help me solve the problem.
            Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
            The board turns on, there is no image.
            Read more. When the power supply is connected, the front panel indicators light up briefly.
            When you press the power button, the button indicator lights up. The board works
            there is no image, there is no matrix initialization, there is no image on HDMI.
            When turned on, the fans do not spin, but when they warm up they start spinning.
            When you turn off the button, the fans spin up to full speed for a short...
            05-11-2024, 03:14 PM
          • Egidio85
            Samsung UE55F8000SZ Turns on and off immediately
            by Egidio85
            good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
            This defect happens continuously, hearing the classic click of the relay every time.
            Power supply board BN44-00636B
            disconnecting the mains and lamps from the power board always causes the same problem.
            Is it normal that without anything connected this power supply turns on and off cyclically?
            any suggestions on what to check?
            thanks in advance
            03-11-2025, 12:45 PM
          • mostachio
            Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
            by mostachio
            Hi Badcaps,
            I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
            TV Details:
            Model # - TH-65DX700Z
            Symptoms:
            The television turns on and displays a picture then makes a clicking sound and turns off.
            I haven't opened it up yet but...
            09-04-2024, 02:32 AM
            High Pressure Sodium Yard light when air conditioner turns light momentarily turns of
            I have had these 70 watt high pressure sodium yard lights for many years now probably at least 15 years or more and there is a protection diode that after several years starts to go bad and when it does this it has momentarily shutting down the light and then a few minutes later it starts working again
            This about the forth time I have fixed this one and you can tell if it the diode or not if it lights up and it only shuts down when the air conditioner turns on then it is the diode
            If it cycling on and off constantly then it is the bulb itself that is the issue
            06-03-2023, 05:24 PM
