DELL se2416h
  • Jane
    • Aug 2010
    • 189
    DELL se2416h
    Hello ,
    DELL monitor se2416h
    What do you think the problem, like that at the video below, is caused by?
    https://www.youtube.com/watch?v=I2-wBg9-SqA
    The monitor is only pluged in to mains ( no other input) and turned on.
    Anyone experienced a such problem?
  • DanPoka
    by DanPoka
    02-15-2025, 05:05 AM
    by momaka
    03-15-2023, 10:17 PM
  • Ifixstuff9
    Dell SE2416h monitor power cycles - very weird behavior
    by Ifixstuff9
    Hello all,
    I have a dell SE2416h monitor that power cycles at somewhat random intervals. When the monitor is first powered on after being off for a few hours, it lasts 15-30 mins before the first power cycle. After that, the cycles progressively get more frequent until the monitor cycles every few seconds.
    I'm not sure what is causing this, but maybe something is overheating, causing the monitor to shut off? That would explain why it gets worse with time.
    Now here is where things get weird (at least to me, this might be some some common symptom I've...
    04-20-2019, 07:03 PM
  • Jesus Coder
    Issues Reviving Old Dell 2408WFPb Monitor
    by Jesus Coder
    I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
    06-25-2023, 02:33 PM
  • ChristianBr01
    Dell 34 inch U3419W Monitor with thin stripes on partial screen
    by ChristianBr01
    I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
    This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
    This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
    Does someone have seen this before?...
    05-23-2025, 06:06 AM
