Dell U3014 - discoloured corner, shadow
  • Pete9-3
    • Feb 2022
    • 6
    • United Kingdom
    I have acquired this monitor few months ago with dying backlight strips. Fitted new ones and all was good for a month or two.
    Out of sudden issue poped up with right top corner being discoloured, sometimes it looks like colours being reverted, lighter instead of darker etc. Also picture is not so smooth towards right edge of the screen, with horizontal lines being visible, and slightly dimmed.
    When system boots up instead of apple logo I get white vertical line in its place going from top to bottom.
    Apart from this monitor seems to be working ok.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Dell U3014 - discoloured corner, shadow
    I'd take it apart and make sure all your LVDS ribbons are clean and seated well....
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Pete9-3
      • Feb 2022
      • 6
      • United Kingdom
      Will do. Can I use Isopropyl on these?
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        Yes.
        Team : 49813
        Join in!!
        Team Stats
        • Pete9-3
          • Feb 2022
          • 6
          • United Kingdom
          These cables were sitting tight. I have removed and cleaned them but nothing has changed at all.
          Any other suggestions please?
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16956
            Not really, other than taking the panel apart again and making sure a LED bead isn't wonky; causing the discoloration....but that wouldn't cause the lines.
            Team : 49813
            Join in!!
            Team Stats
            • Pete9-3
              • Feb 2022
              • 6
              • United Kingdom
              Any clue whether it could be panel or electronics?
              I've tried to press any visible ribbon when monitor was on, nothing has changed again. It didn't get better or worse what makes me hope it is not a panel.
              Also picture seems to be divided in four horizontal bands on the right side with every band being darker at the bottom of it. I assume it would be hard to explain such an discolouration caused by backlight LEDs?
              I would appreciate any suggestions as it seems to be decent monitor.
              I must admit that stripping the panel again would be a pain but can be done if need be.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                It's hard to tell, it could be either....but the seat of my pants says tab bond or tcon issue....maybe you got a little rough with it when changing the LED's initially. Tab bonds are damaged very easily, they're not repairable....so if that's the issue, the panel essentially is toast....but I would still recheck every connector inside that monitor.
                The discoloration I've seen a few times, typically pressure points (twist in the panel) or as already suggested; a wonky LED bead.
                FWIW, I have a fleet of U3011's that I'll never part with until I just can't fix 'em no more! This was the last CCFL model before the 3014 and LED backlighing.... So very reliable!
                Team : 49813
                Join in!!
                Team Stats
                • Pete9-3
                  • Feb 2022
                  • 6
                  • United Kingdom
                  I have tested a bit further today. I have re-seated all cables between boards, and ribbons between little board stuck at the back of a panel and drivers if i can call it like that above.
                  I've dismantled panel again and lifted lcd up to see nice and even backlight underneath. Doesnt look this causes an issue.
                  I rubbed along these tap bonds how you called them when monitor was on at both ends and was trying to manipulate them gently to see eventual issues.
                  None of these have made any change. Visually it is all in good condition.
                  I have measured few voltages but have nothing to reference to. Do you have any sort of schematic for either this model or one before by any chance?
                  I have also taken few additional pictures as few things might have been described incorrectly before.
                  First of all this discoloration in right corner is not permanent to start with. As you can see in attached photos at the beginning with blue background issue is not visible, or barely visible. Once something light coloured land there it becomes worse. Also you will see that side bar in app window is causing ghosting line above same as mouse cursor. I have also noticed image retention after light coloured objects being placed in this corner.
                  Even menu at the bottom causes visible artefacts at the top of the screen.
                  I am trying to add a video but not sure how to.
                  Does it still look at broken panel to you?
                  added video link: https://photos.app.goo.gl/AxJ9irEGF9EousLdA
                  • F R 2568
                    Dell Latitude 5420 does not start (no post) need help to find the reason why
                    by F R 2568
                    Hello all,
                    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                    If the laptop is only connected to the AC adapter (battery removed):
                    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                    The power/battery...
                    01-08-2025, 05:45 AM
                  • diamon
                    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                    by diamon
                    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                    Pictures of these boards:
                    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                    Dell...
                    02-28-2024, 12:51 PM
                  • OntarioTL
                    Dell 5410 greyed out BT
                    by OntarioTL
                    Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                    If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                    Dell Lattitude 5410
                    Service Tag...
                    07-25-2025, 01:28 PM
                  • lalle-
                    Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                    by lalle-
                    Hello!
                    I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                    [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                    I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                    The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                    I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                    08-11-2024, 02:01 PM
                  • federalhouse
                    **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                    by federalhouse
                    I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                    **Background:**
                    I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                    **What I've Tried So Far:**
                    1. I accessed
                    08-01-2024, 07:03 PM
