Chimei CMV 221D - Question about replacement capacitors
  • Agent24
    I see dead caps
    • Oct 2007
    • 4962
    • New Zealand
    Got a Chimei 22" LCD, faulty of course, otherwise I wouldn't be posting here
    It powers on, tries to start the lights but fails. Previous owner tells me the picture is showing if you put it in a very dark room (I have not verified that)
    PSU\Inverter is using CapXon and Taicon.
    Three of the CapXons (220uF 25v) are bulging and I suspect all the rest aren't great either.
    I'm wondering if Nichicon HE are good? I think I read something here that they weren't. Because for one capacitor value they are the best replacement (meets or exceeds old capacitor specifications in ESR and Ripple but is cheaper than others) Also they have highest life (10,000 Hours)
    -David VanHorn
  • PlainBill
    • Feb 2009
    • 7034
    Re: Chimei CMV 221D - Question about replacement capacitors
    The full list is here. Nichicon HE's are most likely better than the originals, just not the best possible series. I'd say use them.
    PlainBill
    • Agent24
      I see dead caps
      • Oct 2007
      • 4962
      • New Zealand
      What would you suggest instead?
      -David VanHorn
      • seanc
        • Nov 2008
        • 1319
        Looks the same as my 22" Viewsonic (Cheimei panel inside).
        I re-capped with Panasonic FM all round, working fine apart from a whine in standby - still not got round to troubleshooting it.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4962
          • New Zealand
          How did you deal with the 2200uF capacitor?
          In my case, no capacitor can be taller than 20mm or so. I looked up the specifications for the FM series, and the 2200uF 25v is 35mm high
          Funny thing though, the CapXon datasheet specifies this capacitor as being 25mm high, but the one I have is 20mm high
          -David VanHorn
          • seanc
            • Nov 2008
            • 1319
            Maybe I popped an FC in there.
            I'll open it up tomorrow and check.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4962
              • New Zealand
              Never mind, I'm an idiot. It's actually a 10 volt capacitor...
              That explains the size difference!
              -David VanHorn
              • seanc
                • Nov 2008
                • 1319
                OK. Never mind Let me know if it sings when it's alseep.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4962
                  • New Zealand
                  PlainBill
                  Do you think Panasonic FM would be better than Nichicon HE for this though?
                  -David VanHorn
                  • seanc
                    • Nov 2008
                    • 1319
                    Panasonic FM are much lower ESR than Nichion HE, but if they're what you have to hand and you want to test it, try them.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4962
                      • New Zealand
                      I don't have anything to hand. I'm looking at what I can order from RS Components
                      The FM sure is lower ESR than the HE, but in comparison to the original Taicons the FM are actually closer.
                      HE seems to match closest to the CapXon KFs though.
                      I think I'll end up buying a mixture of FM and HE actually.
                      -David VanHorn
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4962
                        • New Zealand
                        For the 1000uF 10volt, I already have some Rubycon ZL 16volt.
                        However the ESR is 3 times lower than an HE or FC and original Taicon PW\PZ (0.023 vs 0.068)
                        Do you think these ZL would be OK to use instead or is the difference too great?
                        -David VanHorn
                        • japlytic
                          • Oct 2005
                          • 2086
                          Nippon Chemi-Con KZM or Rubycon ZLH or Nichicon HV (if you can get them) or equivalent have a 6k-10k hour lifespan under worst-case conditions.
                          LCD monitors and TVs can get quite hot inside...
                          • PlainBill
                            • Feb 2009
                            • 7034
                            There is a lot of confusion about the ESR spec. The value published is the guaranteed MAXIMUM value at the stated temperature, when new. The actual value will be much lower than that.
                            Two things to remember: First of all, the lower ESR results in a higher surge current at the moment the monitor is plugged in. The power supply stays on as long as the monitor is plugged in. Once the power supply reaches operating voltage (less than a second after the power cord is plugged in) the low ESR doesn't result in a higher surge current through the SMPS.
                            The second thing to remember is low ESR is better.
                            Somewhere last fall I described the results of testing a number of new and used caps in a TV I had repaired. Several (that had bulged tops) had an ESR of several times the rated value. Most of the original caps read well below specs. Some of the original read lower after two years of use than the new caps I was installing.
                            PlainBill
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4962
                              • New Zealand
                              But isn't higher surge current from lower ESR a bad thing and may damage components in the PSU?
                              -David VanHorn
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4962
                                • New Zealand
                                Unfortunately I don't think so. Only RS-Components is any good to order from (relatively cheap and stocks decent brands and free shipping)
                                Farnell might do some but they cost a lot more.
                                And Digikey etc have far too high shipping ($50)
                                RS-Components seem to like Panasonic FC\FM, Nichicon HE and Rubycon ZL. There are a few others too but they don't seem to have the full ranges for any brand.
                                -David VanHorn
                                • pedro
                                  • 199
                                  • AUSTRALIA
                                  PlainBill
                                  I had a Cisco 877 router presented for possible restoration to normal operation. All caps were Nichicon with good (aka to spec) ESR except ... two CapXon 6800/6.3V which had bulging. Replaced them with FM's (as that size isn't a stock one here in my preferred Hitano range). The FM's quoted ESR is ~0.014 from memory and they measured 0.01x (x doesn't show on my ESR meter). The CapXon's read 1.4 and 1.5 - 100 times the FM's!
                                  Didn't fix the problem though :-(
                                  Friends don't let friends buy Samsung ....
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4962
                                    • New Zealand
                                    Well I've ordered new ones, trying to match the specifications of the original CapXons and Taicons as best I can.
                                    The originals seem to have lasted about 3 years so these new ones of much better manufacture should be good for a long time to come I guess.
                                    Hopefully they fix the problem as well
                                    -David VanHorn
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Did you hookup a console to the 877? If yes, what messages do you get?
                                      --- begin sig file ---
                                      --- end sig file ---
                                      • pedro
                                        • 199
                                        • AUSTRALIA
                                        Sorry, wasn't wanting to hijack the thread. No mesages, no function. There is a short on the +5.2V rail. The plugpack is rated 4.4A and loads up nicely on a dummy load, but into the 877 the rail burps up to about 2.7V and then collapses, cycling about 2Hz. All LEDs blink in sympathy. Replacing the caps hasn't altered that.
                                        If only I had a schematic <sigh> ...
                                        • dragon3x
                                          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                          by dragon3x
                                          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                          power on.
                                          Here are some examples :
                                          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                          switching supply area).
                                          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                          than 6.3 V.)
                                          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                          I replaced capacitors with aluminum-polymer.
                                          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                          03-21-2025, 02:46 PM
                                        • slybunda
                                          AA and AAA battery charger capacitors?
                                          by slybunda
                                          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                          it has inside:
                                          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                          2 x 470uf 16v LZ105c branded as G.Luxon
                                          not heard of these brands are they any good?
                                          iv attached photos of the charger and the board inside for an idea on the type of...
                                          12-24-2023, 04:41 AM
                                          by sam_sam_sam
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • the_rem
                                          Unknown transformer : how to find a good replacement part ?
                                          by the_rem
                                          Hello guys,
                                          I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                          I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                          04-23-2025, 01:48 AM
