LG Flatron L1910S DEAD
  • thetonywarren
    • Feb 2013
    • 169
    I have a LG Flatron L1910S that is dead, no led's no backlight nothing.......I took off the back and took a look at the caps, all appear to be good, although I know that's not a true test......I took voltage readings at CW301, Without the main board connected, Im getting 5vdc and 14vdc, WITH the main board connected, Im getting 4.13vdc and 16vdc. Please see pictures for details, I think the attached diagram is correct for the SMPS. Any thoughts or suggestions where to look next....I can send better pictures and take measurements if needed.
    Thanks in advance for any help.
  • R_J
    • 9609
    Re: LG Flatron L1910S DEAD
    I would start by replacing C109 (c108 schem) and C107. See if this fixes the low +5v. It may also be that C205/C206 are weak
    • thetonywarren
      • Feb 2013
      • 169
      I changed out C205/C206 with new caps 1000uf/25v, but no change, I guess I'll need to source new caps for C109 and C107, as I dont have those values on hand......
      • thetonywarren
        • Feb 2013
        • 169
        Is it possible to subsitute the 0.47uf cap @ C107 with another value? I found a cap to replace C109, but dont have one for C107, not sure if that's a possibility or not?????
        • thetonywarren
          • Feb 2013
          • 169
          I have two caps, one of 2.2uf and another is 0.22uf, will either of those be ok???
          both are rated at 50v
          • R_J
            • 9609
            I would suspect C108 first as it is for the vcc of the ic. You could check this voltage with the main connected, but be careful not to short the ic. and this is on the hot side of the power supply. Looks like this vcc should be about +12VDC
            I would just bridge the 0.47µf with the 0.22µf and see if it help the 5 volts stay up, Just solder it across making sure the leads don't touch anything else.
            • thetonywarren
              • Feb 2013
              • 169
              Before I saw your reply, I soldered in the 2.2uf in place of the 0.47uf just to try it, and it came right on.....I'll get a new 0.47uf and put that in its place when it comes in......I'll update when I get the new 0.47uf cap.......
              • R_J
                • 9609
                Good to here, I would replace C109 (33µf/50v?) as well, the circuit is on all the time and those small caps dry out over time.
                • thetonywarren
                  • Feb 2013
                  • 169
                  Yep, I appreciate the help, I actually replaced every cap on the SMPS, so the bad one was the only one I didn't have on hand.....go figure.......
                  • thetonywarren
                    • Feb 2013
                    • 169
                    FYI, I replaced the 0.47uf cap and it's working now, I appreciate the help....
                    Here's a pic of the screen afer cap replacement....
                    • double_DD
                      How can I be sure that my EC chip is dead?
                      by double_DD
                      As the title suggests, how can I be sure that my EC chip is really dead?
                      I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                      Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                      03-12-2025, 07:47 AM
                    • disorder
                      ps5 edm-033 dead after hdmi/usb ports destroyed
                      by disorder
                      hello guys,
                      i need help to repair a edm-033 ps2
                      history : as always hdmi port and usb ports destroyed after unplugged
                      after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                      so i changed it
                      now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                      but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                      i don't see any projection of liquid metal on pcb.
                      01-14-2025, 12:48 PM
                    • zunasthegreat
                      Chieftec GPS-450-AA with dead 20N60C3
                      by zunasthegreat
                      Hello everyone hope all doing well!
                      I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                      09-01-2024, 07:12 PM
                    • Beton
                      Finding a dead short component
                      by Beton
                      Hi guys!
                      I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                      So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                      I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                      I have a bench PSU and if I try to inject voltage the voltage...
                      12-10-2021, 01:05 PM
                    • FiguringITout
                      MSI Raider GE75 - Not posting, probable dead CPU
                      by FiguringITout
                      Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                      Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                      07-25-2024, 07:27 AM
