Dell U2413 capacitors
  • Griffmadár
    • Nov 2021
    • 5
    • Hungary
    Hello.
    Can somebody give me the which capacity and how many capacitors are in Dell U2413?
  • Griffmadár
    • Nov 2021
    • 5
    • Hungary
    Re: Dell U2413 capacitors
    Just in case if somebody need the full list of the capacitors of PSU and Video board.
    Electrolyte Capacitors
    680uF 25V 6 pcs
    470uF 35V 2 pcs
    470uF 25V 2 pcs
    120uF 450V 1 pc
    100uF 10V 5 pcs
    100uF 16V 5 pcs
    100uF 25V 2 pcs
    47uF 16V 1 pc
    4,7uF 16V 1 pc
    56uF 50V 1 pc
    220uF 16V 2pcs
    47uF 50V 3pcs
    Aluminium Organic Polymer Capacitors
    To identify the right ripple current I give the brand too.
    Lelon 100uF 16V 4pcs
    Lelon "OCRU" 560uF 10V 2pcs
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • petehall347
      100nf and 100uf precision capacitors
      by petehall347
      i am wanting to calibrate my multimeters and for this i require a 100nf and 100uf precision capacitors . trouble is i can't find them ....
      08-13-2024, 06:56 AM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
    • FluxCap123
      Dell U2312HM Why are these capacitors different colors?
      by FluxCap123
      I have a Dell U2312HM monitor with a bad power regulator. As part of the repair I was going to replace the capacitors near the regulator. All 4 capacitors are the same size/voltage but two are brown and two are black (see attached photos). The reference numbers on the two different capacitors are: 1301(M) and 1321(M). Does anyone know what they mean? Can I use the same replacement capacitors for all four?
      Any advice would be appreciated. Thanks....
      12-06-2021, 08:48 AM
