Dell U2413 capacitors
  • Griffmadár
    • Nov 2021
    • 5
    • Hungary
    Hello.
    Can somebody give me the which capacity and how many capacitors are in Dell U2413?
  • Griffmadár
    • Nov 2021
    • 5
    • Hungary
    Re: Dell U2413 capacitors
    Just in case if somebody need the full list of the capacitors of PSU and Video board.
    Electrolyte Capacitors
    680uF 25V 6 pcs
    470uF 35V 2 pcs
    470uF 25V 2 pcs
    120uF 450V 1 pc
    100uF 10V 5 pcs
    100uF 16V 5 pcs
    100uF 25V 2 pcs
    47uF 16V 1 pc
    4,7uF 16V 1 pc
    56uF 50V 1 pc
    220uF 16V 2pcs
    47uF 50V 3pcs
    Aluminium Organic Polymer Capacitors
    To identify the right ripple current I give the brand too.
    Lelon 100uF 16V 4pcs
    Lelon "OCRU" 560uF 10V 2pcs
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • petehall347
      100nf and 100uf precision capacitors
      by petehall347
      i am wanting to calibrate my multimeters and for this i require a 100nf and 100uf precision capacitors . trouble is i can't find them ....
      08-13-2024, 06:56 AM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
      Dell Thunderbolt Firmware
      by SMDFlea
      Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
      Some models have a choice of 2 different firmwares, it depends on the dell SKU.
      The SKU is in brackets (****)
      EDIT: NVM65...
      01-26-2025, 06:22 AM
