Hi there, I have a Dell 1704FPTt LCD monitor which has developed a fault. When I turn it on, everything appears as normal, ie I can see the desktop if connected/or see the Dell screen logo, however the backlight goes out after about 2 secs - power light still on. The display is still visible if i shine a bright light at the panel. I have tested another identical panel and it does the same thing with the same PSU and electronics of the 1704. I've been reading on here that its a problem with one or more of the 4 inverter transistors - all caps on the board appear to be in good condition with no bulging etc. The transistor model in my LCD is AOU402 (x4) in a TO-251 package. I intend to replace these however over here in the UK so far my search for this part has been unsuccessful, I can only find some from the Ebay USA. So my question is can i subsitute this part (AOU402) with a C5707 (2SC5707) part? If not are there any alternatives to the AOU402 transistor? Thanks
Dell 1704FPTt - Backlight goes out after a couple of secs
Re: Dell 1704FPTt - Backlight goes out after a couple of secs
Hi, I have a Dell 1704FPt with the same problem. The screen comes on for 2 seconds and then it goes to black. I opened it up but didn't find any bad caps. Being a stubborn cuss I replaced a bunch of likely suspects anyway. No luck, so I ordered a new inverter board and put it in. I still get the same symptoms when I turn it on. I know I'm putting more money into this monitor than its worth, but did I mention I'm stubborn? Anyway, I'm looking for ideas from the kind and smart folks on this forum. -
Retiredcaps has written a good article on this,
Use the search feature and look for troubleshooting 2 sec to black.
Al.Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!Comment
No you can't substitute the 2SC5707 ( NPN Transistor) for the AOU402 (N-Channel MOSFET).Comment
ASSUMING the inverter you purchased is actually new, working perfectly, the problem is one of the first two.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
The fastest and Easiest way would be to substitute one or two known good ccfls one at a time to your inverter board see if the 2 sec to black problem goes away.
Al.
Now where is a good place to get a couple new ccfls?Comment
You called it! I finally got around to opening the thing up and took the lamps out and plugged them into the inverter. The lower set of lights were arching across between the bases of the two lamps and the inverter shut down in self defense.
Several members here have had good experiences with ccflwarehouse.comComment
Got the new ccfl's. Put them in and it fired up just fine. Now I have another problem. The picture resolution is poor and I can see shimmer around the edges of objects. I tried all the menu adjustments on the monitor and screen settings in XP. I also swapped it out with a computer with a good flat screen monitor, cords and all. No change. I'm considering putting the old inverter back in though I would think the trouble would be in the board that drives the screen. I appreciate the continuing help.Comment
--- begin sig file ---
--- end sig file ---Comment
I also had corrosion/oxidation on the... -
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by Chivo77hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
1- After receiving power SIO_SLP_S0# goes high and never changes.
2-every...07-03-2025, 09:20 AM -
by mioszHi,
I'm trying to fix friend's Dell, it had liquid damage in the past, but as far as I know it was fixed in professional service. It was working fine for quite some time, except for dead battery, but recently there was blackout in the building and after power was restored, laptop was broken. When I got it, it was posting, but OS didn't boot, also backlight was gone. After some tinkering I switched off secureboot and it started booting normally, but backlight issue persisted. I opened it up and started looking for issues. Checked both fuses on display and all fuses on motherboard which I... - Loading...
