Dell Inspiron 15 3558 - no backlight
  • miosz
    • Mar 2024
    • 6
    • Poland
    I'm trying to fix friend's Dell, it had liquid damage in the past, but as far as I know it was fixed in professional service. It was working fine for quite some time, except for dead battery, but recently there was blackout in the building and after power was restored, laptop was broken. When I got it, it was posting, but OS didn't boot, also backlight was gone. After some tinkering I switched off secureboot and it started booting normally, but backlight issue persisted. I opened it up and started looking for issues. Checked both fuses on display and all fuses on motherboard which I found and everything looks ok. After some measurements all I found is that BL_ENABLE signal in display is 0.0V (but not shorted to ground), BL_POWER was ok, at around 19V. Display model is NT156WHM-N12. I traced it back to notebook motherboard, but I ended up tracing it to NPCE285PA0DX-GP IC (pin BLON_OUT) and it was 0.0V all the time. I also measured L_BKLT_EN and it was 3.3V. Does it mean that there is software issue or NPCE285PA0DX-GP is bad, or it can be something else? After I found out that BLON_OUT is 0.0V, I don't really have idea on what to check next.
    Motherboard model is: Iris HSW/BDW 14216-1 Rev:A00
    Notebook doesn't have dGPU
    Screen model is NT156WHM-N12
    Regards,
    Milosz
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Voltage on pin20/21 of edp connector LCD1
    D5202/D5201-voltage on all pins
    U5201-voltage on all pins
    Give us these measurements. the measurements should be done after pressing power button.
    • miosz
      • Mar 2024
      • 6
      • Poland
      Thank you for your answer
      Here are measurements:
      D5202
      1 (BKLT_CTRL) - 3.17V
      2 (eDP_BKLT_CTRL) - 0V
      3 (EC_BRIGHTNESS) - 3.37V
      D5201
      1 (LCDVDD_EN) - 3.2V
      2 (EDP_VDD_EN) - 3.37V
      3 (LCD_TST_EN) - 0.00V
      U5201
      1 (EN/LCDVDD_EN) - 3.2V
      2 (GND) - 0.00V
      3 (VOUT/LCDVDD) - 3.36V
      4 (VIN#4) - 3.37V
      5 (VIN#5) - 3.37V
      LCD connector:
      PIN 20 - 3.17V
      PIN 21 - 0.00V​
      I'm not sure if I mapped correctly pins of D5202/D5201, I assumed that physical pinout matches pinout on schematics.
      Regards,
      Milosz
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        D5202 measurement seems suspect as its pin1 & 2 are perhaps connected together with a pcb jumper trace. You can check continuity with RN5201,pin7 to D5202 and the pin which beeps is pin1.
        U5201 is working fine. What is the LID status? Is it located on power switch or mb?
        • miosz
          • Mar 2024
          • 6
          • Poland
          So it looks like that jumper (R5222) is missing:
          Click image for larger version  Name:	20240314_202453.jpg Views:	20 Size:	919.0 KB ID:	3235060
          I traced R5222 pads and it looks like pins are swapped, so it should be like this:
          D5202
          2 (eDP_BKLT_CTRL) - 3.37V
          3 (EC_BRIGHTNESS) - 0V
          I also measured LID_CLOSE#_C signal and its 0.00V
          Regards,
          Milosz
          • miosz
            • Mar 2024
            • 6
            • Poland
            Small update - I did some more software-side testing. I started with bios update, but it didn't change anything. But I also noticed that power supply is detected as 0W power, which cause system to run very very slow. I tried another power supply (both genuine), but issue peristed. Also for unknown reason internal display disappears when Windows starts, there is no way to switch to internal display, I can only use external monitor via HDMI. So internal display works fine in BIOS, but in Windows it's unavailable. I did drivers update with dell tool, but still only external display is visible.
            Regards,
            Milosz
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              PS_ID is very important and there is something wrong here and probably this is the real issue.
              measure voltage on both sides of PR4205 and check its 33 ohms. often this resistor goes bad.
              Voltage on PQ4201-all pins?
              • miosz
                • Mar 2024
                • 6
                • Poland
                PR4205 looks fine (33Ω, 3.31V on both sides), but PR4206 seems to be missing
                PQ4201 voltages:
                1 (PS_ID_R2) - 3.31V
                2 (PSID_DISABLE#_R_C) - 5.15V
                3 (PSID) - 3.31V
                no significant changes after pressing power button
                Regards,
                Miłosz
                • miosz
                  • Mar 2024
                  • 6
                  • Poland
                  One more thing - I attached logic analyzer to PS_ID_R pin of DC1 connector and to PSID_EC line and in both cases all I got was 10 reset signals:
                  I tried two different power adapters and in both cases it was the same.
                  I also checked continuity between small middle hole in power socket and DC1 PS_ID_R pin and it seems to be fine. What else can I check here?
                    DELL Inspiron 3558 Notebook 3000 Specification for Upgrade or Repair
                    This specification for the DELL Inspiron 3558 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3558 boardview and 3558 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 3558...
                    09-06-2024, 08:00 AM
                    DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                    This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                    09-12-2024, 03:36 PM
