Alright guys i am wondering if anyone could help me i have a computer monitor from belinea that is faulty, it basically comes on shows the picture fine but aftr about 2 seconds it goes black but the green light stays on. If i then press it off and back on the display comes back for 2 seconds and goes off the screen is a proview PV190WCLMCA4H and im told its a pretty common issue but does anyone know what i can do to fix it? Help is apreciated
Belinea 19inch monitor
Re: Belinea 19inch monitor
Originally posted by UKForceAlright guys i am wondering if anyone could help me i have a computer monitor from belinea that is faulty, it basically comes on shows the picture fine but aftr about 2 seconds it goes black but the green light stays on. If i then press it off and back on the display comes back for 2 seconds and goes off the screen is a proview PV190WCLMCA4H and im told its a pretty common issue but does anyone know what i can do to fix it? Help is apreciated
The problem is referred to as the 'Two Seconds to black problem'. It has been discussed repeatedly in a number of threads. There are a number of possible causes, but the first step is always the same - open the monitor up. If any caps are bulging, replace them all. If anything is in doubt, post pictures of the boards.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. -
Originally posted by UKForceCheers bill i have checked them before as it was suggested to me a few months ago and ive just had another look and they all look normal i cant see anything abnormal.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Ok my camera isnt very good but i took pics of both boards.
http://img62.*************/gal.php?g=picture0001mk.jpgComment
Originally posted by UKForceOk my camera isnt very good but i took pics of both boards.
Things don't look good for your monitor. Not only are the pictures useless (too low resolution and too dark), you apparently didn't read my request. I don't need a picture of the logic board; I need a picture of both the top and bottom sides of the power supply / inverter board.
Don't use photobucket. Attach them to your post. It doesn't have to be that hard. Do it this way.
I appreciate the replies but i dont know a lot about this there are two boards in the monitor and i took pictures of them both although as i said before my camera is rubbish. Seems like too much hassle for me to correct the issue being a novice so i think ill have to either throw it out or send it to a professional, again thanks for the replies and i can only apologise for wasting your time.Comment
Originally posted by UKForceI appreciate the replies but i dont know a lot about this there are two boards in the monitor and i took pictures of them both although as i said before my camera is rubbish. Seems like too much hassle for me to correct the issue being a novice so i think ill have to either throw it out or send it to a professional, again thanks for the replies and i can only apologise for wasting your time.
There's only one way to advance past the novice stage, and you won't find a better teacher than PB. He doesn't charge much either, unless you want to send him and his wife back to Hawaii for a few weeks!Comment
Maybe I can help. I have a Belinea 19'' monitor too (1905s). The problem was (is) monitor working but with a pinkish hue on the screen then black after 4-5 sec. I placed an order for new CCFLs (very expensive in this country) and I am still waiting for them to arrive from the US.
I am attaching some pictures of the power supply + inverter unit (component side) and the following link for its diagram http://www.4shared.com/file/10988829...ECTRONICS.html
(I found these pictures on the web because mine don't look too good)
I'll keep you posted on how it goes
CiaoComment
Cheers i will try and take some good quality pictures of it soon and ill post back but ill have to get hold of some testing equipment like wrog said, i was kinda hoping i could just buy a replacement part and be done with it. Technology ehComment
Originally posted by UKForceCheers i will try and take some good quality pictures of it soon and ill post back but ill have to get hold of some testing equipment like wrog said, i was kinda hoping i could just buy a replacement part and be done with it. Technology eh
The management of the firm is overjoyed because it was fixed so easily. This attitude changed when he presented them with a bill for $10,000. They are outraged to be charged so much when all he did was hit it with a hammer. After the screaming dies down, the repairman prepares a new bill. $10.00 for hitting the equipment, $9,990.00 for knowing where and how hard to hit.
In this case, there are a number of possible causes for the problem. These include one or more bad CCFLs, bad wiring to the CCFLs, an inverter transformer with a shorted or open secondary, a bad solder joint in the inverter area, a bad component in the inverter monitoring circuitry, or a bad driver. It is possible to repair the problem by methodically replacing every possible component, but it is much easier to perform a few tests and identify if the problem lies in the inverter drive circuitry, in the CCFLS and their wiring, or in the monitoring circuitry.
by Rick_1234Good evening, gentlemen.
I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
https://drive.google.com/file/d/1L6S...ew?usp=sharing
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
by sew333My pc:
10850K stock 4800mhz stock Kraken X73 good temps
2x16 GB DDR4 GSKILL 3000mhz XMP
Seasonic Tx-850 Ultra Titanium
Gigabyte Rtx 3090 Gaming OC
Aorus Z490 Pro Gaming
1 TB SSD
4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
Power... -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
- Loading...
