ACER AL2017.....not working...Led comes on....with-flashlight can see image
+ More Options
Posts
  • Welchs101
    • Sep 2008
    • 979
    Re: ACER AL2017.....not working...Led comes on....with-flashlight can see image
    frankNstein,
    I am gathering a list of items to order from digikey ........ I have the fuse on my list (btw....i do have 3 fuses.....i found a couple) are there any transistors you think i should order? Even if it turns out i dont need them i dont have a problem going ahead to order since i think they will be cheap.
    • Welchs101
      • Sep 2008
      • 979
      frankNstein,
      Regarding the Q202 (marking 14 transistor).
      I found on the single resistor part number you sent me where the resistance could either be 10k or 22k nominal. SInce i am measuring a base to emitter resistance of ~ 21k............i should probably order
      the
      DDTA124GUA
      does this sound right to you?
      • Welchs101
        • Sep 2008
        • 979
        frankNstein,
        I looked at my Q201 and compared it to yours. I believe yours has the markings of "W2K" and mine has the markings of "K72". So they are different at least in the markings (see my enclosed pic of K72).
        I will keep looking to see if i can find more information on the W2k and K72 devices. If i cant find them i may start a thread here on bad-caps to ask if anyone else knows what they are........i have had sucess with other people finding parts that i could not.
        also, you mentioned you replaced your U200 device. Where did you buy it from? Was your U200 device defective?
        • frankNstein
          • 35
          #64
          I bought the U200 from E Bay I had to buy a lot of 4 and would be glad to sell one to you however I don't think yours is defective, I think the problems we are having are in the circuit that drives the output transformer or possible the transformer itself. I will do some checking today on the K72 and see what I can find. Great idea on starting the new thread.
          • alexanna
            • Mar 2010
            • 1346
            #65
            http://www.s-manuals.com/smd Is A place I found to help identify smd componets. Hope it helps. Al
            • frankNstein
              • 35
              #66
              I had a little time this morning and found a replacement and the data sheet for the K72. I think it is about the same as the W2K but with a diode. I will try to do some more troubleshooting this weekend and probably order the replacement for my board. Here is the data sheet, hope this helps.
              • Welchs101
                • Sep 2008
                • 979
                Thanks! That looks like the K72 part.
                I am still searching (when i have the time) for the W2K part. I would like to find a datasheet or something to confirm exactly what it is so you can get the right part.
                • Welchs101
                  • Sep 2008
                  • 979
                  frankNstein,
                  I am about ready to place an order to digikey for some electrical parts......are there any parts you think i should order?
                  • frankNstein
                    • 35
                    #69
                    At this time I would say just the fused and I think it was Q202 if you want to change it, I think you will find it is OK. Good luck finding the W2K, I haven't had any luck so far.
                    • Welchs101
                      • Sep 2008
                      • 979
                      Measure with multimeter devices Q201, Q204, and Q208.
                      Note: I have enclosed a picture to show where Q201, Q204 and Q208 are located on the board. I have also labeled each of the pads: 1,2 or 3
                      I have also included the datasheets for these devices.....at least what i know at the present time to be the data sheet for these devices.
                      Q201:
                      Resistances:Black, Red
                      1 to 2: Open
                      1 to 3: Starts at 7.6Kohm and then begins to increase
                      2 to 3: 1.37MegOhm
                      Resistances:Red,Black
                      1 to 2: 1.6Megohm
                      1 to 3: Starts at 5Kohm and then begins to increase
                      2 to 3: Open
                      Diode-checks: Black, Red
                      1 to 2: No beep no reading
                      1 to 3: 0.58V beep
                      2 to 3: 0.223V Beep
                      Diode-checks: Red, Black
                      1 to 2: Starts at 1.7V and increases No beep
                      1 to 3: Starts at 2.18V and goes to about 2.25V no beep
                      2 to 3: No beep no reading
                      Q204:
                      1 to 2: 4.72kohm
                      1 to 3: 0.884Kohm
                      2 to 3: 5.6Kohm
                      1 to 2: 4.72kohm
                      1 to 3: 0.883Kohm
                      2 to 3: 5.6Kohm
                      1 to 2: 1.6V No beep
                      1 to 3: 0.539V beep
                      2 to 3: 0.868V No Beep
                      1 to 2: 0.591 Beep
                      1 to 3: 1.7V No Beep
                      2 to 3: 1.73V no beep
                      Q208:
                      1 to 2: 1.63Meg ohm
                      1 to 3: 0.881Kohm
                      2 to 3: Open
                      1 to 2: open
                      1 to 3: 0.880Kohm
                      2 to 3: 1.63Meg ohm
                      1 to 2: 0.577V beep
                      1 to 3: 0.538V beep
                      2 to 3: No Beep, No reading
                      1 to 2: No Beep, No reading
                      1 to 3: 0.540 Beep........surprising that got beep both ways see above
                      2 to 3: 0.88V No Beep
                      • frankNstein
                        • 35
                        #71
                        Thanks for your help. I will do some more checking today.
                        • frankNstein
                          • 35
                          #72
                          Could you please check the resistance of Q204 again. Just from (1) to (3), R/B and B/R. I found that that transistor on my board has a resistance of about 450 in both directions, in circuit and out. I have ordered Q201, Q204 and Q208 for my board. I am quite sure that Q204 is the problem but I thought I would just order them all because of shipping cost. Some are on back order so I am not sure when I will receive them.
                          • rjndebruyn
                            • Nov 2010
                            #73
                            OKey, Im also busy for a long time with this power supply and also no luck for me. My Part No is 19M005 rev 00A. Does some of you have scematic diagram of it??? My FETswere broken, also Q201 and Q204 (and of course the caps) Replaced it, fuse gone and Q 201 and 4 also gone again.
                            • blackrider1
                              • May 2011
                              • 28
                              #74
                              Here you have a DAC-19M005 datasheet, I posted on the Fixing a DAC-19M005 Power Supply thread:
                              https://www.badcaps.net/forum/showth...217#post165217
                              http://www.megaupload.com/?d=ZZHAGME6
                              Although 6 months later, FrakNstein and Welchs101, Did you fixed your boards finally?
                              • blackrider1
                                • May 2011
                                • 28
                                #75
                                Well, finally I got it working. According to the DAC-19M005 datasheet, I decided to follow the line from 16,5 V to the backlights transformer (from F200 ahead), and replaced Q204 (it was burnt, as you can see in the first picture),Q201,Q203 and Q208 ( Q203 and Q208 were okay but I replaced them too).
                                And Q200,Q202 ,ZD200 (weird meassures when testing),Q207 and D216 (They were okay too).
                                And finally, not necccesary but I did it, Q209 and Q210.
                                And now, it´s working.
                                PS: I replaced for the first time all caps (2 bulged and others),Q205 and Q206and ,although they were okay, F200,R210 and R206, but didn´t still had backlights. I didn´t got any blown fuse, so my problem was different than yours, but finally I fixed it. You can see the pictures here:
                                https://www.badcaps.net/forum/showth...143#post167143
                                post #94
                                  by momaka
                                  03-15-2023, 10:17 PM
                                • maralexbar
                                  How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
                                  by maralexbar
                                  I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
                                  It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
                                  If anyone knows how to force the external monitor as primary for Notebooks of those models
                                  11-02-2024, 09:18 AM
                                • 3D Modelka
                                  AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
                                  by 3D Modelka
                                  Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
                                  02-09-2024, 02:42 AM
                                  09-06-2024, 05:27 AM
                                  Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                  This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                  09-07-2024, 05:00 AM
