ViewSonic Model VG920 - No Display/No Power Light
+ More Options
Posts
  • browork
    • Mar 2010
    • 71
    I have a ViewSonic Model VG920 - No Display/No Power Light.
    Looking at the only other VG920 thread on these forums I did the first troubleshooting step, measuring the voltage on the large capacitor. No voltage.
    "In the case of a totally dead power supply, one quick test is to measure the DC voltage across the large capacitor. Note Toasty's comments on safety; those are minimum precautions. The voltage across the cap should be roughly 1.4 times line voltage. For the US you should read about 165 volts DC." by PlainBill
    I then unplugged the monitor, remove the PSU and tested the fuse. It is blown. I now know I will have to replace the fuse, but is there anything else I can look for before I order the fuses?
    I live in the middle of nowhere Kansas. I am aware more often then not a bad fuse is caused by other bad parts. Nothing really pops out at me looking at the board, but I'll include pictures, maybe you will see something I missed. I would like to order everything I might need at once. Any advice would be appreciated.
  • PlainBill
    • Feb 2009
    • 7034
    Re: ViewSonic Model VG920 - No Display/No Power Light
    Thank you. This is fun. Better than finger painting.
    I've identified the components in the power flow path. The most likely cause of the fuse blowing is the bridge rectifier. Other possible suspects include the power FET, and the main filter cap (the large black one lying on it's side.)
    Check the bridge by measuring resistance from each lead to each of the other three leads. If you use the 200 ohm scale on a DMM it should read open between all leads with the possible exception of the two end leads.
    PlainBill
    • browork
      • Mar 2010
      • 71
      Thank you for your response.
      I tested the bridge rectifier with my DMM and all leads read open. I assume this means it is good?
      If I remember my basic electronics class from more then a decade ago FETs are tested with an Analog MM, all I have is a DMM. I am not sure why I remember that, and I may be totally in left field because I cannot think for the life of me why it should matter. Either way I do not remember how to test the FET. Do you suggest that I just replace it? Or is there more troubleshooting you wish me to preform first?
      Also will badcaps.net have all the parts I will need?
      Thanks again for your help.
      • PlainBill
        • Feb 2009
        • 7034
        Well, it means it probably isn't shorted. The next step would be to repeat the test using the Diode Test range of your DMM.
        Check the resistance between the three legs of the FET, first with the DMM on the 200 ohm range, then on the diode test range.
        Badcaps may; however he specializes more toward the motherboard repair niche. I prefer to use Digikey.
        PlainBill
        • browork
          • Mar 2010
          • 71
          Testing the bridge rectifier in diode mode leads, numbered 1-4 from left to right (by your picture)...
          Black 1 Red 2 - 589
          Black 1 Red 3 - 581
          Black 1 Red 4 - 572
          Black 2 Red 3 - open (reverse leads still reads open)
          Black 2 Red 4 - 576
          Black 3 Red 4 - 584
          Testing the fet in ohms 200 range leads, numbered 1-3 from left to right (2 being the raised lead, I assume that is the gate)...
          They all read open.
          Testing the fet in diode mode leads, numbered 1-3 from left to right....
          Black 1 Red 2 - open (reverse leads reads 1800)
          Black 1 Red 3 - 661
          Black 2 Red 3 - 572
          • PlainBill
            • Feb 2009
            • 7034
            Black 1 Red 2 - 589
            Black 1 Red 3 - 581
            Black 1 Red 4 - 572
            Black 2 Red 4 - 576
            Black 3 Red 4 - 584
            "What we've got here is a failure to communicate". (For three points, what movie?)
            The way I want it done:
            Hold the black probe on 1. Readings with the red probe on 2, 3, 4.
            Hold the black probe on 2. Readings with the red probe on 1, 3, 4.
            Hold the black probe on 3. Readings with the red probe on 1, 2, 4.
            Hold the black probe on 4. Readings with the red probe on 1, 2, 3.
            QUOTE=browork]Testing the fet in ohms 200 range leads, numbered 1-3 from left to right (2 being the raised lead, I assume that is the gate)...
            They all read open.
            Black 1 Red 3 - 661
            Black 2 Red 3 - 572[/QUOTE]
            Ahh, I think that's OK.
            If the above readings are OK, try this test. Take a 40 - 100 Watt 120 volt light bulb and use it to bridge the fuse. Plug in the monitor. How bright does the light bulb glow? Measure the voltage across the large capacitor.
            PlainBill
            • browork
              • Mar 2010
              • 71
              Finally a question I can easily answer - 1967 Cool Hand Luke. I think there is another more modern film it is in too, but nothing is popping into mind at the moment.
              By the way, my Army education just taught me basic electronic theory and how to pluck and chuck. No wonder the government is broke, they throw away millions of dollars in repairable circuit cards (and that was just me personally).
              black probe on 1. Readings with the red probe on 2(595), 3(587), 4(578).
              black probe on 2. Readings with the red probe on 1(open), 3(open), 4(582).
              black probe on 3. Readings with the red probe on 1(open), 2(open), 4(589).
              black probe on 4. Readings with the red probe on 1(open), 2(open), 3(open).
              Give me a few on the other test (about an hour)... I have some other work to do first. And do you really want to know how bright the light is?
              • PlainBill
                • Feb 2009
                • 7034
                Well, sorta. The idea of the bulb is to limit current. If the bulb glows at full brightness, there is a problem that we have not identified yet. If the bulb varies in brightness; or if it starts off very bright, then dims, there may not be a short.
                One thing I forgot - measure the resistance of the thermistor. It's in there to limit surge current when the monitor is plugged in. If that shorted, the initial surge could blow the fuse.
                PlainBill
                • browork
                  • Mar 2010
                  • 71
                  Resistance of the thermistor read 11.6
                  With the light bulb...
                  The light bulb flashes. Standard 60w 120v GE household light bulb. I never expected that.
                  DC voltage across the large capacitor reads 158v. The green power light comes on...
                  When the light bulb flashes, the green power light turn amber then goes out. After the flash the green power light comes back on.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Ohhh, SOMETHING appears to be drawing too much power. Is it the LCD panel or the inverter?
                    Or you could try going to a 250 watt heat lamp or putting a couple of lamps in parallel.
                    Dang!!! I just realized that in a few years we aren't going to be able to do this. I'm not at all sure that a CFL would take kindly to this treatment.
                    PlainBill
                    • browork
                      • Mar 2010
                      • 71
                      I put a couple of light bulbs in parallel. The green light comes on, turns amber, then goes off, to come on again... Same as with one light bulb, except the light bulbs do not light up at all.
                      Also there is a very faint electric click when the amber light goes out.
                      I don't think I mentioned that the voltage on the large cap drops when the amber light goes out, somewhere around 20-40v, the second the green light comes back on the voltage at the cap jumps back to 157/158.
                      What does the Canadian Football League (CFL) have to do with compact fluorescent light bulbs?
                      • browork
                        • Mar 2010
                        • 71
                        Now to put the light bulbs in a parallel circuit instead of a series circuit... My bad, had some type of brain fart...
                        With the bulbs in parallel this time, still not light... The Green power light comes on, then switches to amber and stays amber... Hitting the power switch turns the LCD off (no power light)... Hitting the power switch again turns the LCD back on, green light, approx five seconds later the light turns amber... Amber light stays on without issue.
                        Looking at the display, it comes on... Says no signal... I plugged a computer in, LCD comes on and stays on... been running 15 minutes now fine... The light bulbs are rather warm however... Is that normal? Could it just be a bad fuse?
                        • browork
                          • Mar 2010
                          • 71
                          Ok correction number two...
                          For some reason a few light bulbs in parallel told me three bulbs... With three bulbs in parallel the LCD works fine... Three light bulbs should be similar to a 360v fuse if I am following you correctly... The fuse on the board is a 250v... So I took one bulb out of the circuit....
                          Now with two bulbs in parallel...
                          The lights come on, mid range, gets brighter to full elimination, then goes out... The LCD comes on, shows a screen when plugged into a computer, then when the light bulbs go out so does the screen... And the green power light goes out...
                          I am a slow learner, but learning...
                          • PlainBill
                            • Feb 2009
                            • 7034
                            It could have been a bad fuse, momentary surge, etc. I would STRONGLY suggest installing a new fuse. Using a length of 14 gauge wire would be a VERY bad idea.
                            PlainBill
                            • browork
                              • Mar 2010
                              • 71
                              We seemed to cross posts, posting at the same time...
                              I now doubt a new fuse would fully fix my issue, as I stated below
                              Edit: I ordered the fuses (5) today... Same type and style that is on it now.
                              • browork
                                • Mar 2010
                                • 71
                                here is a video of what I see...
                                http://www.youtube.com/watch_private...-wsFQsmA4BKTOQ
                                it is private and will be deleted probably within 24 hours...
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Sometimes I explain the theory behind a test, then forget to describe the test. Sometimes I just tell people how to do a test, expecting them to pick up on the theory. Sometimes these don't work.
                                  Some event caused the monitor to suddenly draw enough current to blow the fuse. Usually there is another failure and the fuse protects the circuit board. Rarely there is no apparent cause. This could have been one of those rare events. It could have been a power surge, a defective fuse, bad karma, whatever.
                                  In the event of a 'hard' failure (shorted power FET), bypassing the fuse could do serious damage. I'm talking about shorted rectifier bridge, shorted thermistor, lands burnt off the circuit board. (Recall that a 15 Amp circuit breaker will handle well over 20 amps for a short time before tripping).
                                  My preferred way to test things like this is to use a Variac - a variable transformer. That way I can increase the voltage slowly while monitoring the current, and avoid nasty (expensive) surprises. Most people don't have one sitting on their workbench. By using a light bulb (or several light bulbs in parallel), we limit the current. Think of it as a layman's variac.
                                  A 100 watt 120, volt light bulb has a resistance of just over one ohm when hot. Three of them in parallel have a resistance of about .35 ohms. By starting with one bulb and adding them in parallel you are increasing the voltage to the monitor, making sure it doesn't suddenly draw a large amount of current. The fact that the monitor worked for an extended period of time with three bulbs in parallel leads me to believe it will work with a fuse in place of the lamps.
                                  PlainBill
                                  • browork
                                    • Mar 2010
                                    • 71
                                    Funny part is that I think I have a a variable transformer in storage. When I started my small town computer repair business I took over an old TV repair shop. It was complete with thousands of old TV parts and test equipment. I cataloged everything and put it in storage in case I might need to use it later.
                                    I will update this thread when I get the fuses and replace it, doing a 24 hour burn-in test to make sure it will work fine or if it fails again.
                                    Odd part is that it is a 250v fuse, so that is one huge power serge to take it out and nothing else. Of course more then 2A would take it out too, so who knows.
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      A few words on fuse ratings. The voltage rating is the voltage that they will interrupt without arcing. Actually, I believe it is a fraction of the voltage they are tested at. IIRC, the standard test for a household 15 Amp fuse was hitting it with 2000 Volts at 500 amps. It had to 'blow' without exploding. That 2A 250 volt fuse wouldn't have any problems operating at 500 or even 5000 VAC as long as the current didn't exceed 2 amps.
                                      PlainBill
                                      • browork
                                        • Mar 2010
                                        • 71
                                        Thanks for the info and the help. New Fuse arrived last week. The monitor has been running great for 5 days now with no additional issues. It appears to have just been a bad fuse.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • ipatch
                                          troubleshooting microsoft surface pro 4 no power no led charge light
                                          by ipatch
                                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                          10-05-2023, 11:59 AM
                                        • russpall
                                          LG 39ln540v - red light flashes twice, no power to LED driver?
                                          by russpall
                                          Hi there,
                                          I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                          The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                          08-27-2024, 01:07 PM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
