So, there I have a Westinghouse L2210NW 22" Monitor that will not power on. It has the "Touch control" buttons, so all of the monitors controls (including power) are of a capacitive touch nature, so I'm hoping this didn't go out on me.
When plugging in the monitor, I can hear a high pitched noise emitting from it (had a similar symptom with a Gateway 22" monitor, turned out to be a bad cap).
I dissembled the unit and saw that the power board had 2 or 3 capacitors that were slightly swolen (the vent had not broken, they were just bowed out a millimeter or two). But the PCB was also discolored near the AC power jack (Not dark brown burned level discolored, just a little browned.) However, all of the solder points and traces on the board appear to be undamaged.
I don't have pictures to post right now, but I will be able to post them later today. I was just wondering if anyone had experience with a discolored power board, and if it was a cause of failure. And also to ask if a capacitor is silghtly swolen, and the vents are not broken, do you think that they have been struck by the plague? Or should they still function at that point.
Just seeing if it's worth throwing $10 in caps into it, or if I should buy a new power board entirely.
