Re: WestingHouse L2210NW Will not power.
What is the part number of that 4 legged chip next to c66 on the backside?
Most inverter boards that I have seen have at least 2 transformers driving the CCFLs. Yours only has the 1.Leave a comment:
It is best to get the same because I'm not sure how a 17 inch length CCFL tube will react in a 22 inch monitor. If the connector, voltage, and current are the same, it shouldn't be a problem.Leave a comment:
also there is another transformer on the board as well should i get the readings from that one as well?Leave a comment:
would any monitor work or does it have to be the same one? cus i have a 17 inch hp monitor just saying aroundLeave a comment:
I just realized that no one including myself asked if you can still see the video/image if you shine a flashlight on the screen? Please answer.Leave a comment:
Do you have another monitor where you can do the CCFL test?Leave a comment:
measurements from the transformer on the top left with the black line on it. everything was tested on 2k ohms
black probe on pin 1, red on pin 2 - .872 ohms
black probe on pin 1, red on pin 3 - 1. out of range
black probe on pin 1, red on pin 4 - 1. out of range
black probe on pin 1, red on pin 5 - 1. out of range
black probe on pin 1, red on pin 6 - 1. out of range
black probe on pin 1, red on pin 7 - 1. out of range
black on pin 1, red on pin 8 - 1. out of range
black probe on pin 2, red on pin 3 - 1. out of range
black probe on pin 2, red on pin 4 - 1. out of range
black probe on pin 2, red on pin 5 - 1. out of range
black probe on pin 2, red on pin 6 - 1. out of range
black probe on pin 2, red on pin 7 - 1. out of range
black probe on pin 2, red on pin 8 - 1. out of range
black probe on pin 3, red on pin 4 - .001 ohms
black probe on pin 3, red on pin 5 - .001 ohms
black probe on pin 3, red on pin 6 - .001 ohms
black probe on pin 3, red on pin 7 - 1. out of range
black probe on pin 3, red on pin 8 - 1. out of range
black probe on pin 4, red on pin 5 - .001 ohms
black probe on pin 4, red on pin 6 - .001 ohms
black probe on pin 4, red on pin 7 - 1. out of range
black probe on pin 4, red on pin 8 - 1. out of range
black probe on pin 5, red on pin 6 - .001 ohms
black probe on pin 5, red on pin 7 - 1. out of range
black probe on pin 6, red on pin 7 - 1. out of range
black probe on pin 6, red on pin 8 - 1. out of range
black probe on pin 7, red on pin 8 - justs around from 1.121 to 1.580 ohms
black probe on pin last-1, red on pin last - 1. out of rangeLeave a comment:
Hi sorry to butt in but this board apart from maybe the pins that connect to the logic board
is the same as the board they use in the acer 1916 maybe another to look at for spares or comparisonLeave a comment:
The 1 should show up on the left hand side of the multimeter display.
Many newbies seem to confuse 1.0 ohms (on the right hand side of the display) with 1 (on the left to indicate out of range). My meter says 0L to let you know it is out of range. So if you interpreted 1 (on the left) has 1.0 ohms, I can see how you thought this transistor was shorted.
stpf1020ct measurements:
1) red on pin 1, black on pin 2. -1.
2) black on pin 1, red on pin 2. -1.
3) red on pin 3, black on pin 2. -1.
4) black on pin 3, red on pin 2. 1.
I suggest if you still have 1 second to black that you move onto checking the CCFLs and tranformers.Leave a comment:
with the mastech
SET TO 200 .7 when touched red and black probes together
k3114 measurements:
com pin 1 red pin 2= 1. set on 2k ohms
com pin 1 red pin 3= 1. set on 2k ohms
com pin 2 red pin 3= 1. set on 2k ohms
sbf1060ct measurements:
1) red on pin 1, black on pin 2. 1. set on 2k ohms also where the diode test symbol is
2) black on pin 1, red on pin 2. flashes from 1. to 800 down to 400 and back up
3) red on pin 3, black on pin 2. flashes from 1. to 400 down to 81 and back up
4) black on pin 3, red on pin 2. flashes from 1. to 800 to 870
4) black on pin 3, red on pin 2. 1.Leave a comment:
I'm sure the mastech will be way better. I hate to ask, but please redo ALL your measurements again. I have no faith in the DT-830b readings (I have one and it is busted).
It shouldn't take you more than 5 minutes to remeasure. Please post results including the reading when you touch the two probes together (this is your baseline/calibration).Leave a comment:
i also have a mastech mas830LLeave a comment:
its a DT-830b digital multimeter
and .7Leave a comment:
See that arrow symbol (in the red box) just right of the 200 ohm? That is your diode test function. Please retest the diodes with that function. Or are the results in post #32 done with the diode test?
BTW, I have that exact same multimeter. It is absolute crap. I got a different one.
Question: After you test the diode in diode setting functionality, switch it back to 200 ohms and touch the red and black probe together. What reading do you get?Last edited by retiredcaps; 08-21-2010, 05:31 PM.Leave a comment:
ok i retested the transistor com 1 and red 3 and it came back 1 at 200ohms
1) red on pin 1, black on pin 2. 130
2) black on pin 1, red on pin 2. numbers seem to keeps going up with out stop
3) red on pin 3, black on pin 2. 129
4) black on pin 3, red on pin 2. numbers seem to keeps going up with out stop
1) red on pin 1, black on pin 2. 419
3) red on pin 3, black on pin 2. numbers seem to keeps going up with out stop
4) black on pin 3, red on pin 2. just shows a 1 on the left sideLeave a comment:
What is the make and model number of your multimeter? For example, you might answer Craftsman model 34555.
For the transistor test, just choose the 200 ohm setting and leave it there. Retest pin 1 to pin 3. If it reads 1 on the left hand side, the multimeter is telling you the resistance is > 200 ohms. If it really reads 10.2 ohms, it is shorted.
For the diode tests, choose the diode setting on your multimeter. It will look like an arrow pointing to the right. Once you find it, retest the diodes.Leave a comment:
sbf1060ct and stpf1020ct measurements look good. The reason you get a resistance that constantly goes up is because your meter is charging the electrolytic capacitors.
Also, if your meter doesn't have a diode/continuity test, use the 2000 Ohm scale only to test diodes. Out of circuit, a good diode will test between 100 and 1000 Ohms one way and appear open circuit the other way. A bad diode will show close to 0 ohms (short circuit) in both directions.Leave a comment:
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
