Help diagnose AOC e2350sd monitor horizontal line
  • mikey5791
    • 504
    • Malaysia
    Hi forum friends,
    A friend bought this working AOC lcd monitor and used it without problem for less than 6 months. Yesterday he brought to me and said it has a horizontal line now and will auto shut off in less than 2 minutes. Btw he had decided to dump it if not repairable. As a friend, i tried my best to help and after opening the case i don' t see anything burned or parts having cold solder joint.
    Fyi, most of the electrolytic caps are tested within 5% range on esr reading except that i changed cap at c918(680uf reads 654.3uf) to a 1000uf cap. Also i added a 680uf 25v cap at c921 for voltage boost if that helps.
    Other that what i had done, i have no more clue as to why the horizontal line is still there and still with auto shut off issue. I would appreciate if someone with experience and patience can kindly guide as what to check and do to bring this monitor to normal working condition. Thanking in advance.
  • mikey5791
    • 504
    • Malaysia
    Re: Help diagnose AOC e2350sd monitor horizontal line
    Hi forum friends,
    Attached the service manual for reference.
    Thank you for reading and possibly helping to diagnose the horizontal line.
    • boyebaran
      • Sep 2015
      • 247
      • iran
      hi
      First, reset the monitor through the menu, then check the flat between the main board and the screen.
      Also check if the signal cable is not connected to the monitor, do you have the same problem in no siginal logo?
      • ulyanoff
        • Jun 2016
        • 12
        • Ukraine
        LCD panel problem, 99% that repair is impossible. (the problem is in the broken contact on the lcd panel glass - on the side lobes, if any)
        • mikey5791
          • 504
          • Malaysia
          Originally posted by boyebaran
          hi
          Hi boyebaran,
          Done the checking flat cable and signal cable. After restart, the horizontal line is still there.
          Hi ulyanoff,
          Looks like it is the lcd panel problem which is not repairable. Thanks for reply.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Not repairable sadly, never seen one fail like that though
              by momaka
              03-15-2023, 10:17 PM
            • Ihandyrepair
              Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
              by Ihandyrepair
              Hi guys
              I just started fixing 4k TV few months ago. so I am still learning a lot
              I got this tv from friend complaint is ghosting or horizontal lines on image.
              never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
              then it started to show the ghosting white image.
              I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
              it has 3 thin small boards at the bottom of the...
              12-05-2022, 04:18 PM
            • cubytus
              Samsung UN50TU8000FXZC shows thin horizontal green line when warm
              by cubytus
              Hi to all,
              I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
              I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
              Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
              01-10-2024, 01:26 AM
            • Kikerumbo
              Mi Curved Gaming Monitor 34" - Horizontal lines
              by Kikerumbo
              Thanks in advance for any help you can provide.
              I have a Mi Curved Gaming Monitor 34". A few weeks ago it started to show (or not showing) horizontal lines. Of course, it's outside of the warranty period.
              After some hours of reading and watching videos I disassembled the monitor and checked the ribbons that go from the TCON board to the panel PCB. If I disconnect the ribbon for the right side of the panel, the other half shows a perfect image. I ordered a "new" TCON, installed it and the issue persists so that tells me it must...
              03-14-2024, 02:48 PM
            • ant3202
              HP 27es - LED monitor - Monitor Flashing On - Off
              by ant3202
              Hi Everyone
              Lately I am experiencing the deja-vu incident on one of the led monitor like this.
              https://www.badcaps.net/forum/troubl...lashing-on-off
              The monitor is HP 27es LED Monitor
              https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
              The monitor will randomly blackout and display no signal and will recover again.
              Sometimes need to power and off again to restore the display but...
              03-20-2025, 07:30 PM
