LCD fried - transformer to blame?
  • veikra
    • Sep 2012
    • 55
    • canada
    Re: LCD fried - transformer to blame?
    I have a sansung 19 inch. The power supply is rather similar to those described in this tread. Even the part numbers on the board matches.
    It turn on and displays the "check cable signal" just fine.
    If I plug in a signal, it will power cycle, as evidenced by the power light, but no image.
    I've changed the shady capacitors and I've noticed the FSDM0565R is noisy when I signal is used. I have a hunch the chip isn't able to handle the load. I've ordered a new FSDM0565RBWDTU and will let you know when it gets here and installed.
    Ps: I've browsed your site a lot in the past and now was a good time to join.
    • Rtech
      • Jul 2010
      • 1095
      Just check to make sure they are compatible!!! I know that one Ebay Sellers product is a 5 pin version,and NOT the 6 pin of the original, and is not the same.
      • jetadm123
        • 2169
        How did you determine it's noisy? Are you looking at it with a scope?
        • veikra
          • Sep 2012
          • 55
          • canada
          I ordered the fairchild exact part number. I just received it. It's noisy enough that I can hear it. It's my best bet so far.
          • veikra
            • Sep 2012
            • 55
            • canada
            Well I replaced the pwm chip , and still behaves the same. Lcd will blink the power led if you hook up the lcd cable. Not as noisy though, but obviously wasn't the true problem.
            I guess my first intuition that the logic board was the problem was right.
            • learnmore
              Help choosing replacement transformer for Levoit 600S SMPS
              by learnmore
              Hello Community,
              I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
              Peace
              LM...
              11-04-2025, 09:35 AM
            • ohren
              Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
              by ohren
              Hello!
              I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
              Measured voltages with no load:
              After rectifier diodes
              12V: 6.17 V
              5V: 5.67 V
              Secondary transformer pins AC measurement (really don't know if this says anything)
              12V: 2-2.5 V
              5V: 1.04 V
              I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
              03-18-2023, 10:33 AM
            • mikey5791
              Is it possible for transformer substitution?
              by mikey5791
              Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
              Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
              My questions are
              1. How do i test to see if the transformer is in good working condition?
              2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
              Hope you guys understand what i was asking. My intention is...
              11-03-2022, 02:11 AM
            • dennis_elx33
              3PHASE STEP-DOWN Transformer in Check
              by dennis_elx33
              Hello All,
              i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
              Problem statement: Power tripped Off
              Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
              Action Done:
              1) Replaced the faulty parts with good spare.
              2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
              12-02-2024, 06:52 AM
              ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
              This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 04:40 PM
